Installing Ubuntu and Linuxcnc 2.9 on Dell Optiiplex 7020
- Bluejayeng
05 Jun 2025 23:03 #329773
by Bluejayeng
Installing Ubuntu and Linuxcnc 2.9 on Dell Optiiplex 7020 was created by Bluejayeng
What downloads do I need to install Ubuntu and Linuxcnc on a Dell Optiplex 7000 series desktop?
- Thank you received: 5330
05 Jun 2025 23:23 - 05 Jun 2025 23:24 #329774
Replied by PCW on topic Installing Ubuntu and Linuxcnc 2.9 on Dell Optiiplex 7020
Last edit: 05 Jun 2025 23:24 by PCW.
- Bluejayeng
06 Jun 2025 00:31 #329782
by Bluejayeng
Replied by Bluejayeng on topic Installing Ubuntu and Linuxcnc 2.9 on Dell Optiiplex 7020
Thank you so much! Where do I get the Ventoy download?
- Thank you received: 7488
06 Jun 2025 00:58 #329783
Replied by tommylight on topic Installing Ubuntu and Linuxcnc 2.9 on Dell Optiiplex 7020
- Bluejayeng
06 Jun 2025 02:39 #329784
by Bluejayeng
Thank you so much! I will reply back with my experience. Several days, maybe...
- unknown
- Thank you received: 323
06 Jun 2025 03:43 #329785
by unknown
Replied by unknown on topic Installing Ubuntu and Linuxcnc 2.9 on Dell Optiiplex 7020
For a pure Unbuntu install, you will have to install your flavour of Ubuntu then install from source, unless you can get the debian packages to work.
If your Ubuntu install uses wayland rather than X11 those guis of Linuxcnc that depend on X11 libs may require a "compatibility" layer, that I've found is somewhat slower than native X11.
Personally I would recommend a the Debian ISO and stick with something that is straight forward and simple to install.
Actually there has been some talk about Canonical using a third graphics subsystem in the furture....and replacing all the basic Linux\Unix utils with Rust equivalents. What's next the return of Unity ?
Time to create page: 0.312 seconds
