Connecting a tool setter and touch probe at the same time
09 Jun 2025 23:02 - 11 Jun 2025 17:03 #330058 by kubes
I did not see any other input other than motion.probe-in, is this used for both a tool length setter and a touch probe?  My HW will support several inputs, and I would like to have each hard-wired in, without the need to swap cables, etc.
Is there a dedicated motion input for a tool length setter? If not what is the best means to have to separate HW inputs?
Thanks!!!
Last edit: 11 Jun 2025 17:03 by kubes.
11 Jun 2025 22:12 #330179 by rodw
Linuxcnc only has one probe input.
You need to devise a way to check which probing method is in use in hal.
One simple way would be to set a digital input in  gcode before probing for tool height.
12 Jun 2025 04:12 #330192 by kubes
Thanks, and to confirm both tool setting and probing use "probe-input"?
If so, then I am considering using mux2 and utilizing M64 and M65 to select which digital input the tool setter and digital probe are connected to.
12 Jun 2025 14:03 #330207 by juliankoenig87
Its way more easy. You can connect two hardware inputs to the probe-input without having to choose the specific one. As long as you do not disconnect for example the 3d probe and having a active probe signal by that.
In this case you can have a workaround and setting the input of the 3d probe to a ignored one while not having a specific tool in the machine. So for example 3d Probe is tool 1 and tool 1 is not in the machine -> disable the hw input of the 3d probe.
19 Jun 2025 02:19 #330482 by kubes
I took a slightly different direction.  By adding a "probe-connected"  hw pin, I can select probe or toolsetter.  This also has the benefit of checking if the probe is connected in the probe sub routine.
As my probe uses a USB-C connector, it's not a USB device; it simply uses D- and D+ as the trigger pins.  And the fact that USB-C can be flipped, I was able to use the CC pins (which are tied together on the probe's USB port) to have a hardware pin when the touch probe cable is connected.
BTW: the toolset I have is NC, so I needed to invert the pin. (I guess lcec does not support '-not')
here the sniplet of my hal:
loadrt mux_generic config="bb2"
addf mux-gen.00 servo-thread
# the UI is connected in postgui.hal
# this handles the hw, which probe is connected
# 3=probe-connected, 4=probe-trigger (NO),  5=tool-setter-trigger (NC)
net probe-connect lcec.0.Z.din.3 => mux-gen.00.sel-bit-00 motion.digital-in-00
net probe-in mux-gen.00.out-bit => motion.probe-input
net probe-trigger lcec.0.Z.din.4 => mux-gen.00.in-bit-01
net toolsetter-trigger not.1.out => mux-gen.00.in-bit-00
net toolsetter-trigger-inv lcec.0.Z.din.5 => not.1.in
Time to create page: 0.378 seconds
