E-Stop Line Number
- flipzip
10 Jun 2025 05:37 #330064
by flipzip
E-Stop Line Number was created by flipzip
Is there a way to indicated what G_Code line you were on after an E-Stop press in QTDragon? Just goes back to 1.
- MaHa
- Thank you received: 241
10 Jun 2025 14:58 #330090
by MaHa
Replied by MaHa on topic E-Stop Line Number
- MaHa
12 Jun 2025 17:14 #330217
by MaHa
I had to set my machine to a certain state, when a new gcode file is loaded, also reset saved last motion.program.line. I did not find any example, suiting the requirements, so did it my own way. This pythoncode is creating a number from the current loaded filename. Unique enough for me.
e.g. 'rectangle_inside_helix_stepdown_no_stepover.ngc' returns 3724037, or 'HalfBallConc.ngc' returns 142356. A 'pin in s32' can handle those numbers
easy to make a comparaison oldfile/newfile and take action.
def newfile():
y=openfile.split('/')
z=(y[len(y)-1])
w=0
for x in range(0, len(z)):
y = (ord(z[x]))
w = w + (((x+1)**2) * y)
return w
The following user(s) said Thank You: cakeslob
- Thank you received: 2181
08 Jul 2025 01:20 #331496
Replied by cmorley on topic E-Stop Line Number
Qtdragon on master will now log the last run line (when in auto mode) if estop,machine off, abort or end of program.
Time to create page: 0.116 seconds
