Raspberry Pi 4B 4GB has operated a very conventional x,y,z mill with a Mesa 7i96 for a couple of years.
WiFi never worked and has been a back-burner issue for a year or more.
Two cubicles:
- Power: VFD, stepper supply, general supplies, AC/DC relays,
- Electronics: RPi, stepper drivers, DC relays, power supplies,
- minimal 240VAC cabling for power supplies, monitor.
Monitor, keyboard and mouse cabled.
WiFi-Extender for workshop 4m from RPi.
Test set-up on workshop bench 6m from Extender.
Bench desktop ethernet cabled to extender, has always had reliable WiFi.
I have two RPi; 4GB and 8GB.
The 4GB is currently LC2.9.2, and I downloaded LC2.9.4 recently to a separate SD card.
Investigated:
- both 4GB and 8GB operate WiFi with either L2.9.2 or LC2.9.4 on the bench no problem,
- confirmed linked to the Extender by switching it Off (house WiFi 5G is at -70dBm),
- both operated with Mesa card Off,
- both fail to launch WiFi in electronic cubicle when mounted or hung in free space.
Also:
- both have identical (as close as I can tell) WiFi set-up,
- both detect the Extender and show signal level at -40dBm,
- both fail to scan for ssid using menu-config in LC2.9.4,
- both respond to "iw dev wlan0 scan" with response for Extender at -40dBm.
Note: test in cubicle has all non-essential supplies Off: VFD, steppers, Mesa, general control,
nothing else in workshop energised, other than air conditioner and desktop.
Need suggestions on which stone to turn over next.
John.
