How to jog when beyond soft limits
- kubes
12 Jun 2025 20:08 #330229
by kubes
How to jog when beyond soft limits was created by kubes
I have soft limits on my axis and absolute encoders. If I power off the machine when I am on the limit (max or min), the machine may move by a 10th (0.0001) or so, once the servos release on power off. This will cause the machine to "move beyond" the soft limit, even if just 0.0001. Once this occurs, I can't jog the axis at all. I have to edit the limits in the ini, jog and reset the limits back.
I would expect you can jog toward the soft limit and beyond to get back into the limits. How can I jog into the limits is I am just slightly over (but over)
- Thank you received: 6917
12 Jun 2025 21:09 #330230
Replied by tommylight on topic How to jog when beyond soft limits
What GUI?
Does the machine have tandem axis/joints?
- kubes
12 Jun 2025 21:38 #330232
by kubes
Replied by kubes on topic How to jog when beyond soft limits
Probe Basic
Not sure what you mean by tandem axis/joint. It's a mill so three axis, defined with axis_ and joint_
To that point, the issue is both before home and after, so joint and axis.
Time to create page: 0.428 seconds
