Problem with my LinuxCNC
13 Jun 2025 09:45 - 26 Jun 2025 01:24 #330245 by jerryluna
Problem with my LinuxCNC was created by jerryluna
Hello,
 have a problem with my LinuxCNC. I run the "LinuxCNC Stepper" I complete my setup and I test each axis separately, it works very well, Once I finish the configuration and I run the shortcut created on the desktop, I can no longer control my axes. When I launch the shortened engine is released, as if I hit the power
Someone has already experienced this problem?
Last edit: 26 Jun 2025 01:24 by jerryluna.
13 Jun 2025 13:40 #330249 by tommylight
Replied by tommylight on topic Problem with my LinuxCNC
Invert the enable pin in StepConf.
You can edit the existing config, click on the right side where you have chosen that pin.
Time to create page: 0.304 seconds
