Replaced Hard drive - now my 'fast move' (SHIFT->arrow |PgUp/PgDn is not working
15 Jun 2025 00:57 #330291 by irwinger
I guess we had a power spike - I know we lost power because the computer had rebooted. But the message was about not being able to find a boot device. After MUCH futzing around - I THINK I may have had damaged my primary SATA port (weird). I could boot the system from a USB and view the drive contents, but I couldn't figure out how to rebuild the boot drive to boot it. I had made backups of the config files 'just in case' (I'm usually a much bigger risk taker and don't bother) and managed to pull them off the drive before I proceeded with a 'nuke and a repave'. When I couldn't get a new system laid down - I thought it WAS the hard drive then. I had an SSD kicking around that I put in and... same problem. That lead me to try a different SATA port and voila - new system installed.
Within this new SSD based system I did the latency test (I was seeing a number like 71,000?) and then ran StepConf just to create the files. Once I had the files in place - I overwrote them with my backups and Bob's yer Uncle - my system was up and running. EXCEPT - when I try the fast move using the SHIFT key - all 3 axes move a random, short distance and then there is a sound like it's moving - but it's not.
I tried to modify the MAX_ACCELERATION  in both the [AXOIS_X] and the [JOINT 0] sections of the .ini. But changing those resulted in a non-start on LinuxCNC. Even as I type this - I THINK the issue might be the stepper timing and not the acceleration. But I'm hoping that the brain trust on LinuxCNC here in the forums can point me in the right direction.
I've searching the online documentation and the 362 page Integrators manual - but there is really SO much underlying knowledge of the workings of Steppers, Servos and 'integration' terminology that just baffles me. I'm still plugging away!
Thanks in advance...
15 Jun 2025 12:44 #330305 by tommylight
Copy your config folder to the configs folder, open it, right click on the .ini file, choose open with, down click on use custom command, under it type linuxcnc, press enter.
Test the machine, does it work correctly?
If yes, run LinuxCNC from the main menu, left select My configs then your config, click on create desktop shortcut, click ok.
Now you have a shortcut on the desktop.
21 Jun 2025 15:38 - 21 Jun 2025 15:56 #330637 by irwinger
Thanks for the response and my apologies for delay and update - retired life got super busy for a couple weeks... I'm not sure I explained the whole episode clearly - I'll try again.
1) LinuxCNC was reinstalled on the same hardware but with an SSD instead of spinning disk.
2) StepConf was invoked to create new .INI and .HAL files for this new installation - there was no attempt to 'configure' anything using StepConf because I planned on copying over the .INI and .HAL files from my previous working install (spinning disk)
3) For grins and giggles - I attempted to load and run LinuxCNC before overwriting .INI and .HAL - of course it didn't work
4) I overwrote the initial .INI and .HAL files with my copies from the working installation (spinning disk)
5) Initial loading and running of LinuxCNC worked fine
6) Thinking I again had a functional system, my mind went into autopilot and my fingers took over - I wanted to move the router to the center of the workspace an pressed the SHIFT-RT Arrow for a rapid move 'X' and... it jumped a bit and stopped
7) Exactly the same with SHIFT-LT Arrow, SHIFT-UP Arrow, SHIFT-DN Arrow, SHIFT-PgUp and SHIFT-PgDn.
I have not yet run a job to see if it works - I doubt it because any rapid moves would cause a problem. I've done some reading on steppers, timing and BASE_PERIOD and I'm trying to find the timing charts for my steppers. I'm thinking that since LinuxCNC uses software step generation, the new SSD may be just too quick? Although - the configured BASE_PERIOD should be independent of the any HD speed.
My other thought is - my latency test resulted in > 70,000 nS Jitter in the Servo Thread and almost 56,000 nS Jitter in the Base Thread. With Steppers - I'm not sure I'm concerned about the Servo Thread numbers, but when using StepConf, the maximum entry allowed allowed for Base Thread jitter is 50,000. While the instructions for the Latency Test say 'abuse' the system when testing... when running a job - I don't much touch the computer for anything significant - certainly no web surfing or multi-tasking other apps.
Not sure any of that update helps you all help me - I'm reading LinuxCNC forums, documentation and Wiki as well as trying to find timing diagrams or tables for my steppers. Anything anyone can suggest would be really helpful... possibly reduce the acceleration?
EDIT: I should have included some hardware specs...
Dell Optiplex 7020
I3-4150 @ 3.5GHz
8G RAM
Samsung 256G SSD
Last edit: 21 Jun 2025 15:56 by irwinger.
22 Jun 2025 19:07 #330720 by andypugh
I am not sure why you used Stepconf at all. You should have been able to just copy the old "linuxcnc" directory from one drive to the other, and carry on as before.
24 Jun 2025 21:25 #330827 by irwinger
Outside of my use of StepConf - any suggestion as to what I might want to look at to understand why the rapid moves of SHIFT-RT/LT/UP/DN/PG UP/PG DN just move a couple inches and then stop? Unless StepConf 'does' something in file I'm not overwriting from my previous working system.
Again - thanks in advance for any suggestions... I know I'm not the quickest getting back, I have a part time job in my retirement which is starting to occupy me more than I like.
Arden
24 Jun 2025 22:16 #330828 by tommylight
27 Jun 2025 21:32 #330936 by irwinger
I'm not sure if you were asking me to upload a video to YouTube showing what is happening - but that's what I did. The video link is here:
youtube.com/shorts/D5WTf5WWpfo
It's very hard to 'see' or hear - but as part of the homing function, the axis slowly approaches the limit switch, then moves away, then back and finally 'jumps' away from the switch.
I tried changing the MAX_ACCELERATION setting in the .INI - in both the AXIS_X and JOINT_0 sections. I halved them but it made no difference. I also attempted to move the sliders at the bottom of the LinuxCNC screen (below the jog section) way down one at a time - but that made now changes.
If I try to run even a simple shape (gcode for a small rectangle) it just 'locks up' like you see in the video when I attempt to press the 'SHIFT-(any arrow).
I'm just buffalo'd - I cannot figure it out.
Arden
27 Jun 2025 21:40 #330937 by tommylight
Set the HOME_FINAL_VELOCITY to something smaller.
If they are not in the ini file, add them for each joint.
27 Jun 2025 22:08 #330940 by irwinger
I added HOME_FINAL_VELOCITY to the AXIS_X / JOINT_0 section(s). I set it to match the value for the HOME_SEARCH_VEL and HOME_LATCH_VEL. I also increased the HOME_OFFSET to -.500000 to make sure there was some visible movement. Nothing changed - it locked up trying to move the axis.
Here is that section of the INI file - in case any of the other entries look odd.
#*** AXIS_X *******************************
[AXIS_X]
MAX_VELOCITY = 1.0
MAX_ACCELERATION = 30.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
[JOINT_0]
TYPE = LINEAR
HOME = 0.0
MIN_LIMIT = -0.01
MAX_LIMIT = 8.0
MAX_VELOCITY = 1.0
STEPGEN_MAXACCEL = 37.5
SCALE = 8000.0
FERROR = 0.05
MIN_FERROR = 0.01
HOME_OFFSET = -.500000
HOME_SEARCH_VEL = -0.050000
HOME_LATCH_VEL = -0.050000
HOME_FINAL_VELOCITY = -0.050000
HOME_IGNORE_LIMITS = YES
29 Jun 2025 20:22 #331013 by irwinger
OK - I don't know how this got so 'catty wompus' but... turns out - it was my stepper setting. Originally - it was 8000 steps /inch. which seems to be what was in my 'backup' .INI. When I checked my step setting and did the math - I realized it should be 4000 steps. That improved the movement, but I was still getting 'follow errors' (or something like that). One thing I DID notice is - I was out by a factor of 2 when I did a G0 X.5 command. I went back to 8000 and suddenly I was out by a factor of 4... oops - wrong direction. Changed to 2000 steps/in and all my errors have gone and I am able to use the machine again.
I have to confirm yet - but I'm using a chinese 'blue' board parallel port controller and I'm wondering if my stepper switch settings are documented wrong.
Anyways - crisis resolved. Thank you for your help - this discussion can be closed.
