Tool changer script
- aeth
15 Jun 2025 16:47 #330317
by aeth
Tool changer script was created by aeth
I want to use an ATC spindle with a rack tool changer. I was struggling to find some ready-made script I could use and perhaps modify that would fullfill this goal. Is anyone aware of an existing implementation that was tested/proven by some people that does this? I was able to find some carousel tool changer scripts/designs, but I explicitly need a simple rack solution since the machine is a router with 1m length I can use for holding plenty of tools.
20 Jun 2025 19:10 #330586
Replied by andypugh on topic Tool changer script
Have you looked at the sample config sim/axis/remap/rack-toolchange
You can run that as a simulator to see if it works like you want, and then look at the way it is done to adapt to your own needs.
It works by re-mapping M6 to call a G-code subroutine.
Time to create page: 0.230 seconds
