Weird problem happening during g71, g70 cycle
18 Jun 2025 19:06 #330465 by arijitdutta
I have been trying to run a fairly simple profile on my lathe- a radius and then a straight z axis move. during the the final g71 pass and also the g70 pass, the x axis twitches after going some distance, gouging a bit into the profile, around 0.3 mm into it whereas it should go straight without the x axis moving. I am unable to troubleshoot this problem at all.
i am posting a link to the video of the problem I am facing, you will be able to see the x axis unwantedly twitch a bit in the last 3-4 seconds if you look closely. any help is much appreciated.
youtube.com/shorts/7KZHbUTbIng
18 Jun 2025 19:22 #330467 by tommylight
Replied by tommylight on topic Weird problem happening during g71, g70 cycle
What value do you have for P in the ini file, if any?
And what value does the servo period have?
Or is this a parallel port setup?
19 Jun 2025 02:10 #330481 by arijitdutta
Replied by arijitdutta on topic Weird problem happening during g71, g70 cycle
I am running this off a 7i96s. I never changed the servo period, so it should be default. The P value for both axis is 1000
19 Jun 2025 03:45 #330486 by arijitdutta
More findings:
I am running g95 with a manual bldc controlled spindle. The jerk happens at around z -17.2 everytime no matter if the spindle was running at 1200 rpm or stopped or at 100 rpm. It never happens before that or after that no matter how much time was given for the axis to reach at that point. So i can safely rule out any problems with electrical noise and such issues (though my control panel isnt good enough).
Now if i change the backlash from 0.08 to 0.0- the problem vanishes.
Even on the graphical interface it looks like a straight like, g70, g71 trie to do a small move at z-17.2 for reasons unknown, for which the backlash motion is triggered. I am not sure yet. Let me increase the backlash to much higher numbers to see if the jerk increases or stays the same as before.
22 Jun 2025 15:14 #330700 by Hobbymate
Replied by Hobbymate on topic Weird problem happening during g71, g70 cycle
Hi. I see you have the 2.9.3 version. How do you get to work, G71. I have error bad character. Thanks
22 Jun 2025 19:36 #330722 by andypugh
Replied by andypugh on topic Weird problem happening during g71, g70 cycle
"Bad character" should tell you which line of the G-code the error is on. This is much more likley to be a problem in your G-code than in the G71 code. (not that I exclude that possibility)
23 Jun 2025 18:44 #330764 by Hobbymate
Thanks for answering. When i run this code from examples its do. G21 G54 G18
F400
O100 SUB
G0 X10 Z0
O101 REPEAT [3]
G1 X[#<_x>-5] Z[#<_Z>+3]
G1 X[#<_x>-5]
O101 ENDREPEAT
O100 ENDSUB
O101 SUB
G72 Q100 X1 Z1 D0.5 I1 R0.3
G70 Q100 X1 Z1 D0.5 P3
O101 ENDSUB
O101 CALL
M2
When from this code i delete G72 line G70 working fine . But when i change G72 to G71 Linuxcnc freezing . Can someone direct me to right path. How to run G71 .
11 Jul 2025 19:32 #331710 by andypugh
I wouldn't expect G71 and friends to accept REPEAT/ENDREPEAT in the profile subroutine. It parses G1,G2,G3 commands into a profile internally then creates a toolpath to cut that profile.
I am not even sure that it can be expected to correctly read #<_x> etc.
The following user(s) said Thank You: Hobbymate
05 Aug 2025 09:57 #332872 by Hobbymate
Hi. Do you have some code with this subroutine working? If possible, can you share? I use Notepad++ to make sure the file is in UTF-8 without BOM, but I get the same problems. Thanks.
19 Aug 2025 12:36 #333669 by andypugh
Look at the files in the sample directory. They should be already part of your installation, but you can also see them here:
github.com/LinuxCNC/linuxcnc/tree/master/nc_files
Look at the lathe_g7* files.
Time to create page: 0.183 seconds
