Why does motion planning use linear interpolation instead of b-splines?
25 Jun 2025 12:11 #330858 by aeth
It's a question that I've been asking myself for quite a while. Linear interpolation is quite limited in its accuracy as well as its ability to maintain constant velocity. Have there been any attempts to replace that with higher order polynomials / b-splines / NURBS etc? I saw the recent great achievement to implement s-curve acceleration (add a setting for jerk), but here I'm thinking more about directly improving the motion planner. I understand that this is significantly more resource intensive, but honestly, for a modern PC it should be trivial to compute.
25 Jun 2025 15:36 - 25 Jun 2025 21:36 #330865 by PCW
I think the main thing here is that there are little real benefits of higher order
interpolation, at least for the speeds, accelerations, and servo period used on
typical LinuxCNC machines.
For example, using a relatively high performance metal cutting machine with say
100 mm/s cutting speed and 0.5G acceleration, the chord error caused by linear
interpolation at the highest centripetal acceleration and at a 1 ms servo thread,
is only about 0.6 microns.
The error just gets smaller a lower speeds and accelerations.
Last edit: 25 Jun 2025 21:36 by PCW.
The following user(s) said Thank You: tommylight, JT
29 Jun 2025 10:06 #330994 by aeth
I see, but for cutting aluminium (i.e. my machine runs at 4000mm/min with a 8mm tool) and high speed machining applications, I'd say this probably starts to play a much bigger role?
06 Jul 2025 17:26 #331400 by cakeslob
I think 100mm/s is still faster than 4000mm/min
The following user(s) said Thank You: RotarySMP, tommylight
Time to create page: 0.108 seconds
