HY_VFD RS-485 HAL config
  • scsmith1451
  • scsmith1451's Avatar Topic Author
  • Premium Member
  • Premium Member
09 Jul 2025 17:19 #331587 by scsmith1451
Replied by scsmith1451 on topic HY_VFD RS-485 HAL config
Spoke too soon.
After verifying the VFD parameters and the loadusr arguments to insure matches, I was able to issue a M3 S6000. The spindle enable relay activated and the spindle ramped up to 6000. However, M5 did nothing and I had to stop the spindle with the VFD control panel.
Next I tried to rerun the M3 S6000 command. I heard the relay activate, but the VFD did not respond. I shut down and restarted LCNC this time it failed to restart complaining that about not being able to communicate with the VFD. Checking dmesg I found that the dongle had migrated from ttyUSB0 to ttyUSB1? I updated the custom.hal and restarted LCNC without issue. This time I issued a M3 S10000 which worked perfectly. but again M5 was ignored.
I've now gone through this sequence several time and each time the VFD starts at the requested speed, then fails to stop. Each time the dongle migrates to a different ttyUSB1/2 port. The last time I issued a start command I noticed that the pyVCP display did not show the speed nor at speed and as I was monitoring the display I saw the OS notify that the dongle had again reattached at a different port.
At this point I'm confident that I can communicate via hy_vfd to VFD, but I'm frustrated that the dongle keeps toggling between ports on its own. Any ideas what is going on and how to resolve the issue?
09 Jul 2025 19:12 #331589 by PCW
Replied by PCW on topic HY_VFD RS-485 HAL config
Just guessing that the port migration is because USB communications were
lost due to EMI as soon as the VFD started.
Does the VFD have a line filter?
I would keep the USB cable as short as possible and try wiring the RS-485 connection
through a common mode choke (a large ferrite bead)
Also check the VFD frame grounding
VFDs radiate EMI like a radio station, and USB is typically quite poor
in EMI resistance.
  • scsmith1451
  • Premium Member
  • Premium Member
22 Jul 2025 13:14 #332179 by scsmith1451
Thanks Peter.,
There was no change after adding chokes at both ends of the RS-485 wire. Checking the wire I discovered that it was not shielded. Ordered a few feet of 18 gauge shielded wire for CNC VFD use. First attempt I received the wrong wire. Finally got the right wire today.
After installing ferrules on both ends with minimum wire exposed and installing it, I double shielded it by adding a choke at the VFD end of the wire as close to the terminal block as I could and grounded the shield at the dongle to the PC.
Restart was successful. No issues running the spindle after the upgrade.
Thank you for your guidance.
Kind regards.
Time to create page: 0.092 seconds
