Mesaflash not working on 7i96s but it pings
11 Jul 2025 04:02 #331686 by Gautham
Hi Everyone,
First of all, thank you in advance for your help. I should mention I am new to Linux, new to CNC, and new to Mesa cards. I have been following the tutorial for getting started with the Mesa 7i96s by talla83 en, but I have been stuck for the last couple of days trying to get the Mesa card found using the Mesaflash command but it always says No 7i96s found. I have tried following tutorials for changing the local IP address, thinking there is a conflict as well as changing the jumper on the card to change the IP address but neither have worked. I wanted to put up my settings here hoping one of you will notice a glaring mistake I have made and could point it out. Thanks once again
https://ibb.co/BH9BbB5R
13 Jul 2025 15:39 - 13 Jul 2025 15:50 #331769 by Cerezas
Replied by Cerezas on topic Mesaflash not working on 7i96s but it pings
Try:
mesaflash --device ethernet --addr 192.168.1.121 --readhmid
Last edit: 13 Jul 2025 15:50 by Cerezas.
13 Jul 2025 15:57 - 13 Jul 2025 15:57 #331770 by PCW
You have the host set to the same address as the 7I96 card
(so you are pinging your host PC)
For a 7I96S set to 192.168.1.121, use 192.168.1.100/24 for the host
For a 7I96S set to 10.10.10.10, use 10.10.10.100/24 for the host
( 10.10.10.10 is suggested rather than 192.168.1.121 as the 192.168.1.XX
range is often overlapped with local DHCP network addresses)
Last edit: 13 Jul 2025 15:57 by PCW.
The following user(s) said Thank You: sk_linuxcnc
13 Jul 2025 17:30 #331775 by tommylight
Replied by tommylight on topic Mesaflash not working on 7i96s but it pings
Andy, did you delete your post?
14 Jul 2025 02:33 #331801 by Gautham
Replied by Gautham on topic Mesaflash not working on 7i96s but it pings
Hey thank you so much, this worked.
