Linuxcnc 2.4.5 with Ubuntu 10.04, Correct file path or structure ?
23 Jul 2025 23:35 #332244 by dunnitagain
There is nothing on the Hard Drive except Ubuntu
24 Jul 2025 00:06 #332247 by tommylight
Do you have any other older PC?
You can install everything on another PC then move the drive to the machine PC and it just works 98% of the time.
What is the PC make/model?
Try pressing F12 for Dell (F8 for Asus and F11 for some others) with the USB inserted and right after powering on, see if it shows a bootable device list.
Try a different USB, i refuse to believe any PC after roughly 2002 will not boot from USB, even earlier PC's mostly boot from USB without issues.
Is the HDD a PATA or SATA?
PATA = 40 or 80 wire flat cable
SATA = small connector with thin wire, usually black or red color.
25 Jul 2025 11:38 #332301 by dunnitagain
I will try that tommorrow , There is no real Identification on the PC, Small Black Box , Has a Motherboard and a Hard drive only.
Time to create page: 0.082 seconds
