Multi-use machine
- dextaca
24 Jul 2025 14:31 #332263
by dextaca
Multi-use machine was created by dextaca
Good day Forum
Just a quick question for the forum, I have a Biesse 37L router that I would like to use it as multi config machine ( plasma cutter , CNC router and 3D printer ) . I would like know if someone can point me on how to make multi config on Linuxcnc so I can make things happen
Thank you
Thank you
- Thank you received: 7488
24 Jul 2025 15:43 #332266
Replied by tommylight on topic Multi-use machine
Easy, just make as much as you need/like of configs that fit your hardware, use the wizard to create each of them.
Although, plasma will not play nice with other features due to huge amounts of fine metal dust that blackens everything.
Time to create page: 0.195 seconds
