Probe tripped during non-probe move deadlock
10 months 3 weeks ago #339873 by tommylight
7 months 6 days ago #344768 by abs32
As a result, I started experimenting with Z-axis acceleration settings to reduce braking time. Previously, the acceleration was set to 2000. When I set the acceleration to 6000, no errors occurred over 14 hours of operation (115,000 measurements). When I set the acceleration to 12,000, I got an axis misalignment error. It works acceptably at an acceleration of 9,000.
The following user(s) said Thank You: pommen
6 months 5 days ago - 6 months 5 days ago #345977 by grandixximo
Last edit: 6 months 5 days ago by grandixximo.
6 months 5 days ago #345979 by abs32
The axis desynchronization issue was caused by an error in my INI configuration—the parameters I had set required a frequency higher than 50 kHz. I changed the servo period, and the error disappeared.
“Probe tripped during non-probe move” is resolved by setting delays. In my case, using an electrical capacitor. Over 2 million activations.
This leads to the conclusion that it would be appropriate to implement a Probe delay parameter in the machine settings. “Feedback” delay. That is, when the probe triggers, the machine must immediately recognize this and begin braking, and then even execute the next command (typically, recording and rebound). And the specified parameter in seconds or milliseconds should not react to a change in the probe’s state.
6 months 5 days ago #345988 by djdelorie
I mentioned this here: forum.linuxcnc.org/39-pncconf/58480-conf...g-dual-y-axes#344832
I have "write a better debounce module" on my todo list. No guarantees ;-)
5 months 1 week ago #346617 by andypugh
I don't think that a better debounce is the solution. We really ought to be able to solve this in the base code. Unless you have a probe that ounces after the machine has stopped moving.
Time to create page: 0.153 seconds
