- LinuxCNC
- General LinuxCNC Questions
- Auto mode, reaching first point of coord then "reading" state, no movement
- _skinner
26 Jul 2025 06:54 #332355
by _skinner
Auto mode, reaching first point of coord then "reading" state, no movement was created by _skinner
Hello,
I was trying figure it out and find answer but without success.
Have You know why in auto mode and MDI sometime machine stuck in reading state without execution of program? Just simple turn off and on again LinuxCNC is helping, but it is not a solution. In machine status I didn't find any interesting thing. Every parameter look same when working normally and when stuck in reading state.
For example if first line is G01 Z5 F100, and when I manually move axis to Z10, then first line of program will be executed, and machine stuck, next line is simple G01 X1 Y1 F100. MDI commands not working then also.
Thank You in advance
27 Jul 2025 15:48 #332416
Replied by andypugh on topic Auto mode, reaching first point of coord then "reading" state, no movement
Which version of LinuxCNC?
Is there any chance that it is related to the spindle-at-speed function?
Is anythng driving spindle.0.at-speed?
- _skinner
28 Jul 2025 06:23 #332457
by _skinner
Replied by _skinner on topic Auto mode, reaching first point of coord then "reading" state, no movement
It is 2.9.4, rpi5 with 7c81. I think is not related to spindle, even probe program don't want work.
03 Aug 2025 19:52 #332755
I don't know if probing waits for spindle-at-speed. It might.
Have you checked the signal with halmeter?
03 Aug 2025 19:54 #332756
Though stuck on "reading" maybe hints at a file access problem.
Is there plenty of space on the SD card? Are the G-code files on the SD or maybe on a network drive?
- LinuxCNC
Time to create page: 0.124 seconds
