7i97T and analogous + Siemens 611
- sin-do-re
27 Jul 2025 15:08 #332413
by sin-do-re
7i97T and analogous + Siemens 611 was created by sin-do-re
Hey everyone
I have managed to completely interface with a Siemens 611, enabling it, clearing faults, reading encoder etc.
they move well when I apply voltage to the analog port.
its a huge tandem machine with two Y axis but I’ll be copying the signal as there’s no need for gantry skew correction.
I’m using a 7i97T but the analog part is not working as intended: no voltage comes out at all!
im using a 7i97T test config from the forums because there’s no PNCconf for 7i97T.
but, although the config runs, I have no analog output in any of the ports.
I assume it is configuration, because the config provided is using pwmgens and MAX_OUTPUT but no analog out or Min/Max.
does anyone have a working config for the 7i97t or 7i97?
thank you
best regards
thank you
best regards
- Thank you received: 5329
27 Jul 2025 16:26 #332425
Replied by PCW on topic 7i97T and analogous + Siemens 611
