7i37-COM
- ChironFZ16
- Thank you received: 12
30 Jul 2025 09:07 - 30 Jul 2025 09:10 #332543
by ChironFZ16
7i37-COM was created by ChironFZ16
Last edit: 30 Jul 2025 09:10 by ChironFZ16.
31 Jul 2025 11:50 #332594
Replied by andypugh on topic 7i37-COM
I think you can probably use a 7i37-TA, but it will need to be wired differently.
But a repair might well be possible.
- Thank you received: 5330
31 Jul 2025 12:44 #332598
Replied by PCW on topic 7i37-COM
Its probably repairable. If it was an output short, its likely just a damaged
MOSFET ( NDT3055 ) A 7I37TA will work as a replacement, but you need to
change the wiring as Andy mentioned.
Here's the BOM:
Here's the BOM:
The following user(s) said Thank You: andypugh
Time to create page: 0.481 seconds
