Interfaces & linear scale for LinuxCNC
- Cysign
01 Aug 2025 11:19 #332621
by Cysign
Interfaces & linear scale for LinuxCNC was created by Cysign
I originally wanted to run a cheap DIY cnc machine using an old Intel Atom dualcore computer which has an LPT connector. But meanwhile I start thinking about higher quality components.
Same specs:
-stepper motors (already exist)
-linear rails for a work area of 1000/600/200mm (already exist)
-spindle Kress FME800 (already exists)
-stepper driver board with 5x Toshiba TB6560 (already exists)
-USB connected hand controller/job wheel LHB04 (already exists)
Now I wonder if I'd better go for an network/USB controlled Mesa card to get rid of that old Intel Atom computer and be able to use any machine (probably a modern notebook).
Also I would like to bux linear scales for my build, but couldn't figure out how they would be connected to LinuxCNC.
Is there a lis with reliable (but not too expensive) supportet linear scales?
And would you rather ust the Toshiba stepper driver board listet above or get some modern alternative?
Since I didn't really start building it, I'm free to change components for the good
I'm going to weld the frame for my machine. So I wonder what's the best way to start? At the moment I think I'm going to build z-axis first and depending on it's dimensions I can design the x-axis, then Y-axis.
But for designing the z-axis I need to know which linear scale system I need to mount and what size it is.
Since this CNC machine is intended to build electrical guitars, I don't require the highest precision, but I'd like to have as small tollerances as possilbe for a reliable pricetag.
Same specs:
- Cysign
02 Aug 2025 20:29 #332694
by Cysign
Replied by Cysign on topic Interfaces & linear scale for LinuxCNC
Sure, but I would get rid of the LPT-port requirement and could use any computer, not only this specific one (if broken one day...).
Which Mesa card would be your go-to in 2025?
And is there a card combining outputs (for the stepper drivers) as well as inputs for linear magnetic encoders or would this be a combination of two cards?
- Thank you received: 5329
02 Aug 2025 20:39 #332695
Replied by PCW on topic Interfaces & linear scale for LinuxCNC
A 7I95T combines the functions, or a 7I96S+ a 7I85, or 7I85S can do it in two cards
The following user(s) said Thank You: Cysign
- Cysign
02 Aug 2025 22:37 #332699
by Cysign
7I95T looks good. But I couldn't find a cheap German oder european source. There's a German shop that has none in stock. Just contacted them to see when it'll be re-stocked
Will this be a good choice for a hobby machine?
de.aliexpress.com/item/1005005087476488.html
- Thank you received: 7488
02 Aug 2025 23:13 #332700
Replied by tommylight on topic Interfaces & linear scale for LinuxCNC
www.welectron.com in Germany has only 7i96S in stock right now
www.eusurplus.com in Portugal has all mentioned above in stock
eusurplus.com/index.php?route=product/product&product_id=64
or
eusurplus.com/index.php?route=product/product&product_id=159
eusurplus.com/index.php?route=product/pr...t_id=105&search=7i85
or
- Cysign
03 Aug 2025 21:51 #332764
by Cysign
Nice idea - but that won't work, since the LPT-port is connected to the motherboard
Would a LPT port have enough inputs and outputs to read linear encoders for 3 axis?
Regarding linuxcnc.org/docs/html/hal/parallel-port.html that should work. So I coult start using the Intel Atom computer and once it's broken, I'll swap over using a Mesa card.
I guess I'll try to install a new version of LinuxCNC on the computer, connect it to the Toshiba driver board and the steppers and see if I can get it rotating.
Maybe I'll order one linear scale and test if it'll work with the LPT connection.
03 Aug 2025 22:18 #332766
-Yes it can read 3 axis be it A/B or A/B/Z, so 6 or 9 inputs, but only in "IN" or "X" mode that most built in parallel ports can do but not all, and you might need more than one parallel port for everything to work.
-No as parallel port is really slow for reading encoders, especially high resolution ones.
You can use a parallel port or two to do some testing and maybe very slow work, but i would not think you can use it for a production machine.
As a reference, you can do 5000-20000 encoder pulse readings per second on a parallel port with a good latency PC, might even go to 50000 with a really good latency PC, but this is to far fetched.
And for reference Mesa can do up to 10000000 pulse readings per second. Yes, that is 10 million.
Yes and no:
- Cysign
03 Aug 2025 22:38 - 03 Aug 2025 22:40 #332772
by Cysign
I see. So is there something like GRBL for output, but used for encoder-inputs?
Like an Arduino or Teensy based encoder-decoder?
I just started um this old computer. There's an old Grub 1.98 with Ubuntu 13 installes. Linux 2.6.32-122-rtai (I probably installed this about 10 years ago
Also I have to change the bios battery, since it is empty.
It has an Intel D425 installed and 4GB memory.
//Edit: github.com/AlexmagToast/LinuxCNC_ArduinoConnector
That might to the trick. I'm sure there's at least one Arduino Mega2560 within the range of two meters around me. Also I can see at least 5 Arduino Uno in front of me
Last edit: 03 Aug 2025 22:40 by Cysign.
- Cysign
03 Aug 2025 23:52 #332775
by Cysign
Looks like installing LinuxCNC isn't as easy as installing a casual linux.I remember I had to burn DVD when I first installed it and I borrower a DVD drive to install it properly.I flashed the image using Rufus 4.7 and booted from the USB flash drive - but then the setup mentions "your installation media coultn't be mounted". Is this a known bug? What's the workaround?Also I was unable to set the BIOS to UEFI mode only. There's no option to disable the compatibility mode - so setup outputs warnings when using USB flash drive in EFI mode.
04 Aug 2025 00:38 #332778
At the error, remove the USB device and wait 5 seconds, insert again the USB and wait 15 seconds, click on YES and next.
Usually that works for this, well almost always.
In case it does not work for you:
Download and install Linux Mint Debian Edition, update and upgrade, then
sudo apt install linuxcnc-uspace
Warning, this might not be the best option for parallel port use as it might end up with quite high latency.
Time to create page: 0.187 seconds
