view > mm vs inches, and tool size display, in AXIS
11 Aug 2025 03:36 #333195 by johnbump
This is probably simple but I can't find it through some searching.
My machine is set up as imperial but I do (basically all) my gcode in metric.
As a result, when AXIS starts it comes up in inches, and I have to change it to metric before touching off tools.  Similarly, the cylinder that represents a tool displays in inches so when I change to mm it's 25 times larger than the job and I can't see anything.
I'm using linuxcnc 2.7.14 and would appreciate any advice.
12 Aug 2025 00:32 #333256 by johnbump
I could totally do that (rounding errors on this machine are so far below its backlash) but then I have to go through all the axes and recalculate steps per unit distance and bleah.
Time to create page: 0.163 seconds
