Hardware requirement if a MESA 7i97T card is used
11 Aug 2025 15:29 #333230 by Hartwig
Hi members,
I got the recommendation from a member to use t< for my retrofit project he MESA 7i97T card.
Would I need another type of MESA as a "motherboard" - or would the hardware list be as simple as listed below:
1x PC with LinuxCNC installed
1x Ethernet cable
1x 5 V DC power supply
1x MESA 7i97T
Thanks a lot and best regards
Hartwig
11 Aug 2025 15:38 #333232 by tommylight
Replied by tommylight on topic Hardware requirement if a MESA 7i97T card is used
1x Ethernet cable
1x MESA 7i97T
That is all you need.
But, it would be advisable to give us more info about the machine/drives/motors, as 7i97T will work with analog servo drives.
If you are sure they are analog, go for it.
Time to create page: 0.127 seconds
