Raspbery pi5 pcie adapter to parport card
- Thank you received: 7488
13 Aug 2025 14:48 #333338
Replied by tommylight on topic Raspbery pi5 pcie adapter to parport card
Pretty sure LinuxCNC does not use Linux drivers for parallel port, it has it's own driver and all it needs is a memory address for it to work, but your results show strange addresses, so try 0 for address in the StepConf wizard, and if that does not work also try
1b80000000
and
0x1b80000000
Do reboot the RPI between tests.
1b80000000
and
0x1b80000000
- unknown
- Thank you received: 323
13 Aug 2025 18:39 #333358
by unknown
Replied by unknown on topic Raspbery pi5 pcie adapter to parport card
I give up, I've tried to explain, given links, but it appears a waste of time.
- KaveMan
14 Aug 2025 02:18 #333380
by KaveMan
Replied by KaveMan on topic Raspbery pi5 pcie adapter to parport card
Thanks. I tried all three variants on both parport cards. Did not work.
Let's not spend any more time on this. appreciate everyone's time and effort.
I'll likely jump back in this fall when I have more time.
- unknown
14 Aug 2025 04:50 #333382
by unknown
It wont work,(the simple explanation since you don't understand\haven't read the links) the RPi SOC doesn't do the memory\port mapping the parallel ports require.
When searching about this a thread I started came up, regarding SPI, mentioned parallel ports don't work with the RPi.
forum.linuxcnc.org/18-computer/51748-eoi...rpi5?start=10#303031
Rather than banging your head against a wall look at the Linuxcnc RIO project. Or get a Mesa 7i90HD, it's really quite cheap if you are based in the USA.
store.mesanet.com/index.php?route=produc...oduct&product_id=291
