multiple estops on separate pins
- LeonDolnicar
14 Aug 2025 09:59 #333394
by LeonDolnicar
multiple estops on separate pins was created by LeonDolnicar
Hello,
I am running a thre axis CNC mill with stepper motors with mesa 7i76eu. I wanted to connect stepper driver alarm outputs to mesa and have them triger emergency stop. I am also planning on adding two additional Estop buttons. I wired them up but then noticed that linuxCNC setup wizard only lets me select one output as emergency stop. Is there a way I can select multiple inputs as emergency stop, or do I have to wire the buttons in parallel and connect them to one input.
- JT
- Thank you received: 593
14 Aug 2025 11:40 #333397
by JT
Replied by JT on topic multiple estops on separate pins
There's a couple of ways, you could use the
Mesa Configuration Tool
or you can add the
estop_latch
component yourself.
JT
JT
- Thank you received: 4150
14 Aug 2025 11:50 #333399
Replied by rodw on topic multiple estops on separate pins
estop-latch is the right way to go with these but a better way is to use joint.N.amp-fault-in IN BIT Should be driven TRUE if an external fault is detected with the amplifier for this joint.
ref: linuxcnc.org/docs/stable/html/man/man9/motion.9.html
This will halt motion.
Your drives may also have a estop input which disables the drive on an estop.
- Online
- Thank you received: 1477
14 Aug 2025 12:22 #333405
Replied by Todd Zuercher on topic multiple estops on separate pins
You can use logic components such as and2 to connect multiple signals to one. But I'm not sure I see the advantage of doing so with an e-stop. Generally an e-stop loop is all in hardware, and the e-stop input to Linuxcnc is merely to inform it of the loop's state.
- Thank you received: 7488
14 Aug 2025 12:27 #333406
Replied by tommylight on topic multiple estops on separate pins
Drive alarms should be wired to joint.n.amp-fault in hal, not to e-stop,
14 Aug 2025 12:39 #333408
Yes as I said. Much cleaner to maintainDrive alarms should be wired to joint.n.amp-fault in hal, not to e-stop,
14 Aug 2025 13:11 #333413
Rod, i did not read your post past "estop-latch is the right way to go", and you know the reason why.
Sorry, this time i should have continued.
Thank you.
Thank you.
