Encoding UTF-8
- JackRay
- Thank you received: 14
31 Aug 2025 17:09 #334193
by JackRay
Encoding UTF-8 was created by JackRay
Hello,I am trying unsuccessfully to create a parametric file for measuring the length and diameter of my tools.I am encountering significant issues with the encoding (UTF-8) of the subs. Either it cannot find the sub, or invisible characters are embedded in my files and LNC refuses to read them. Is there a solution, an editor capable of writing a clean file? Thank you.
31 Aug 2025 17:14 #334195
Replied by andypugh on topic Encoding UTF-8
Which editor are you using?
Looking about on the internet it seems that maybe geany does odd thing in some locales. What's your locale setting?
(eg: unix.stackexchange.com/questions/340469/...ic-encoding-in-geany )
The following user(s) said Thank You: JackRay
- JackRay
01 Sep 2025 15:42 - 01 Sep 2025 15:52 #334235
by JackRay
Replied by JackRay on topic Encoding UTF-8
hello ,
i live in french, i'm french. I used VS code or Thonny
Last edit: 01 Sep 2025 15:52 by JackRay.
02 Sep 2025 12:29 #334266
You could try Geany (which we include in the LinuxCNC distribution because it's quite a well-behaved editor)
Time to create page: 0.207 seconds
