Questions about "Auto Zero" in QT_Dragon_HD probe tab.
  • JohnnyCNC
  • JohnnyCNC's Avatar Topic Author
  • Platinum Member
  • Platinum Member
31 Aug 2025 22:15 #334205 by JohnnyCNC
How can I make the "Auto Zero" button default to ON?  ON a few occasions where I have not used my machine for a couple of months, I forget to set Auto Zero to ON, and then go down a rabbit hole trying to figure out why my machine is not cutting at the correct Z height.
What is the use-case when you would want Auto Zero to be OFF?
02 Sep 2025 22:58 #334301 by cmorley
What version of linuxcnc are you using?
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
03 Sep 2025 03:16 #334310 by JohnnyCNC
I'm using 2.9.4.
When the Z is off, It is usually off by a half inch or so. It all depends on what I was doing the last time I remembered to turn auto zero on.
03 Sep 2025 04:18 #334313 by cmorley
I pushed a change to 2.9 and master so the button state is recorded in the preference file.
Versa probe is based on the original Vers probe routines, which allowed those options.
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
04 Sep 2025 03:09 #334385 by JohnnyCNC
Thanks Chris.
05 Sep 2025 07:35 #334478 by rodw
Changes pushed to 2.9 won't be accessible unless the devs issue a point release. eg 2.9.5
You would probably be better off upgading to master 2.10 branch so you get changes as they happen.
QT dragon is a pretty new GUI and Chris has been beavering away improving it all the time..... :)
  • JohnnyCNC
  • Platinum Member
  • Platinum Member
05 Sep 2025 23:10 #334520 by JohnnyCNC
Thanks Rod. I'll look into upgrading to 2.10.
Time to create page: 0.105 seconds
