Questions about "Auto Zero" in QT_Dragon_HD probe tab.
1 year 2 months ago #334205 by JohnnyCNC
How can I make the "Auto Zero" button default to ON?  ON a few occasions where I have not used my machine for a couple of months, I forget to set Auto Zero to ON, and then go down a rabbit hole trying to figure out why my machine is not cutting at the correct Z height.
What is the use-case when you would want Auto Zero to be OFF?
1 year 1 month ago #334301 by cmorley
What version of linuxcnc are you using?
1 year 1 month ago #334310 by JohnnyCNC
I'm using 2.9.4.
When the Z is off, It is usually off by a half inch or so. It all depends on what I was doing the last time I remembered to turn auto zero on.
1 year 1 month ago #334313 by cmorley
I pushed a change to 2.9 and master so the button state is recorded in the preference file.
Versa probe is based on the original Vers probe routines, which allowed those options.
1 year 1 month ago #334385 by JohnnyCNC
1 year 1 month ago #334478 by rodw
Changes pushed to 2.9 won't be accessible unless the devs issue a point release. eg 2.9.5
You would probably be better off upgading to master 2.10 branch so you get changes as they happen.
QT dragon is a pretty new GUI and Chris has been beavering away improving it all the time..... :)
Time to create page: 0.065 seconds
