Fresh start with linuxCNC and Ethercat
- Yippiekae
01 Sep 2025 07:37 #334219
by Yippiekae
Fresh start with linuxCNC and Ethercat was created by Yippiekae
Hey !
I'm building a cnc mill with a german FS4GM epoxy granite gantry and a Spinogy X22 spindle. It's a small but rigid setup that I'd Iike to control with 400W servos, LinuxCNC and EtherCat.
Since I only ordered the mechanical parts+spindle, I still can avoid some problems (ie latency issues) by choosing the right things on the electronic/control/computer side. Hence this newbie message :
What servo/drivers/computer/other things-I-still-don't-know-about would you go if you had to get them again ?
Cheers,
Flo
Cheers,
Flo
- alexscott
03 Sep 2025 06:40 #334316
by alexscott
Replied by alexscott on topic Fresh start with linuxCNC and Ethercat
The FS4GM gantry with the Spinogy spindle should give you a very rigid platform. Since you’re still in the planning stage, it’s smart to think about the control side early.Hey !
Since I only ordered the mechanical parts+spindle, I still can avoid some problems (ie latency issues) by choosing the right slope game things on the electronic/control/computer side. Hence this newbie message :
Cheers,
Flo
- Hakan
- Thank you received: 454
03 Sep 2025 07:46 #334319
by Hakan
Replied by Hakan on topic Fresh start with linuxCNC and Ethercat
Definitely an Intel network card for EtherCAT.
For one of the Qt interfaces I would not select the slowest computer around.
Time to create page: 0.094 seconds
