Rotary Scanning
- dextaca
05 Sep 2025 12:25 #334490
by dextaca
Rotary Scanning was created by dextaca
Good day Forum
Have a question on point scanning and data file creation. I'd like to scan a part log the xyz coordinates, compare them based on simple math , then adjust the g-code trajectory based on the lowest value of the scan. any suggestion ?
Kindly
Kindly
08 Sep 2025 13:57 #334623
Replied by andypugh on topic Rotary Scanning
This might be as simple as setting the G54 (or similar) coordinate offset with a G10 command using the measured value.
Then leave the G-code unchanged, and based on G54 zero as the low point.
Time to create page: 0.170 seconds
