G81 Spindle Reversal Between Each Hole
17 Sep 2025 18:39 #335138 by andypugh
Replied by andypugh on topic G81 Spindle Reversal Between Each Hole
Remapping is way way over my head and messing around with it can crash my machine
The simplest case of remapping is fairly straightforward. It starts off looking a lot like a subroutine in its own file (which is also a possibility)
See section 2.6 here: linuxcnc.org/docs/stable/html/remap/rema...xample_remapped_code
Your ngc file would probably just contain the usual G83 but wrapped with a spindle reversal, and passing-through the XYZRQ etc parameters.
17 Sep 2025 19:18 #335140 by MaHa
Replied by MaHa on topic G81 Spindle Reversal Between Each Hole
When we had a similar problem with stringy chips, drilling holes with carbide drill with trough coolant in CrMo4, a modified G83 cycle solved that. Only retracting by 0.2mm after 2mm. Continue this 2.2mm / retract 0.2mm  steps until
final depth, we made all the 120 holes without interruption and big loss of time. I think feed was about 0.12/rev
The following user(s) said Thank You: tommylight, Darium
Time to create page: 0.341 seconds
