Python pendant logic problems
- heffamonster
17 Sep 2025 03:01 #335105
by heffamonster
Python pendant logic problems was created by heffamonster
Greetings ,
You guys are awesome BTW
I am working on a python logic script to control some switches, a button, and a couple encoders connected to the p1 connector of the Mesa 7i96s IO with 5vdc going to power the encoders. They are just simple switches wired one side to P1 input, the other side to ground. I have been working with ChatGPT to develop this script but it can only go so far. It really has trouble with the little details. (id; .get() set()) I don't totally understand it either and need some help. I have included my hal filses and the python script. Any and all help is greatly appreciated.
- heffamonster
17 Sep 2025 03:03 #335106
by heffamonster
Replied by heffamonster on topic Python pendant logic problems
Sorry i uploaded them twoce
- unknown
- Thank you received: 323
17 Sep 2025 05:14 #335114
by unknown
Replied by unknown on topic Python pendant logic problems
All the Hal files are useful, with what you supplied there is no telling how your mesa card was setup.
More time wasted with using AI. You don't requires script to assemble the logic for a simple pendant with buttons and an mpg, it can all be done via Hal.
A mesa card does require a seperate Hal component to be loaded for an encoder, if you are using the on board encoder and don't require it for any spindle speed or position feedback. The encoder Hal component is usually used with the parallel port, when no encoder is available, ie with with a mesa card, tho you could set one by using mesa input pins as would you would do via a parallel port.
To tell the truth I did write a Hal component that takes the count from a encoder on the mesa card and some other pin inputs for scale and such, but this was just a way to simplify the Hal file for myself, it is not really required, all the connections can be made using seperate Hal components.
If you do want to use a script, the best way to get the values of the input pins and the encoder counts is to simply create the pins needed.
I would honestly browse the forum, I'm sure a topic came up recently regarding a configuration for a pendant.
Forget AI for Linuxcnc, I have seen some very upset people when it is pointed out the code produced is more or less useless.
One reason for the concept of Hal in Linuxcnc is so that a non programmer can just join this bit to this and this bit to that without having to indulge in programming.
Now my thoughts usually don't run in an ordered manner, what you best might is to describe by words, schematics, drawing on the back of an envelope, blackboard or for us more of a Luddite bent maybe a drawing on a cavewall. Once we know how you want to connect this bit to that bit answers will come.
But yeah read the docs, have a browse of some of the supplied components and see what best fits what you need to do.
What follows is the ranting old man, can be ignored. Or hysterically laughed at.
It does seem quite ironic that AI isn't a great help with a project such as Linuxcnc. CNC controlling the machines and AI replacing the use of the human mind.
Once humanity achieves Actual Intelligence may Artificial Intelligence maybe of some use.
17 Sep 2025 18:56 #335139
Replied by andypugh on topic Python pendant logic problems
Can you describe what you want to happen? I have a feeling that the AI might be over-complicatiing things. But without knowing your requirements it is hard to tell.
Does the MPG connect to a Mesa counter, or only to GPIO?
- heffamonster
17 Sep 2025 23:04 #335144
by heffamonster
I don't have an MPG. It's all done with switches. 1. empty 26. PE
2. empty 25. empty
3. momentary switch 24. empty
4. mode switch 23. empty
5. DT (encoder) 22. encoder power 5vdc
6. SW (encoder) 21. X,Y,Z; Z-Y: unused GND
7. CLK (encoder) 20. momentary GND
8. Z (X,Y,Z switch) 19. encoder GND
9. X (X,Y,Z switch) 18. D-pad GND
10. Y-Z switch 17. down
11. unused 16. up
12. empty 15. right
13. empty 14.left
Its all connected to a parallel port breakout board, connected to the P1 of the Mesa 7i96s. I don't NEED a python script. If i can handle the logic through hal, that would be the best way for me. I don't even need the logic. I just want to get them functioning and then i can add features later. I have a spindle encoder so i would need to load at least one more. The diagram doesn't reflect and additional encoder connected to 1,2,12. At the end of the day, Ai does complicate otherwise basic tasks. Thank you for the responses. If you need anymore information, just let me know.
2. empty 25. empty
11. unused 16. up
12. empty 15. right
13. empty 14.left
- heffamonster
18 Sep 2025 00:13 #335146
by heffamonster
Would something like this work? net pendant-encoder-a pendant.encoder-a [HMOT](CARD0).0.gpio.034.in
net pendant-encoder-b pendant.encoder-b [HMOT](CARD0).0.gpio.035.in
net pendant-encoder-btn pendant.encoder-btn [HMOT](CARD0).0.gpio.036.in
net pendant-jog-a pendant.jog-a [HMOT](CARD0).0.gpio.037.in
net pendant-jog-b pendant.jog-b [HMOT](CARD0).0.gpio.038.in
net pendant-jog-btn pendant.jog-btn [HMOT](CARD0).0.gpio.039.in
net pendant-momentary pendant.momentary-btn [HMOT](CARD0).0.gpio.040.in
net pendant-mode-sw pendant.mode-sw [HMOT](CARD0).0.gpio.041.in
net pendant-axis-x pendant.axis-x-sel [HMOT](CARD0).0.gpio.042.in
net pendant-axis-y pendant.axis-y-sel [HMOT](CARD0).0.gpio.043.in
net pendant-axis-z pendant.axis-z-sel [HMOT](CARD0).0.gpio.044.in
net pendant-z-y-sel pendant.z-y-sel [HMOT](CARD0).0.gpio.045.in
net pendant-dpad-up pendant.dpad-up [HMOT](CARD0).0.gpio.046.in
net pendant-dpad-down pendant.dpad-down [HMOT](CARD0).0.gpio.047.in
net pendant-dpad-left pendant.dpad-left [HMOT](CARD0).0.gpio.048.in
net pendant-dpad-right pendant.dpad-right [HMOT](CARD0).0.gpio.049.in
net pendant-coolant-hw pendant.coolant-hw [HMOT](CARD0).0.gpio.050.in
I know im missing something.
- unknown
18 Sep 2025 10:49 #335152
by unknown
I'm probably missing the point, but how are the signals connecting to the internal Linuxcnc signals ?
Look this is an example of a MPG setup using the parallel port but it illustrates some basic routing of hal signals.
- Thank you received: 4150
23 Sep 2025 19:54 #335338
Replied by rodw on topic Python pendant logic problems
When AI reports info from a post of mine on the forum, you know it at best is only superficial.
There is an example in the docs on a mpg using an encoder. It is easy to convert to a Mesa MPG encoder input but I think on the 7i96s you need extra firmware from mesa web site and forgo some I/O pins.
- Thank you received: 5329
23 Sep 2025 23:46 - 24 Sep 2025 00:09 #335344
Replied by PCW on topic Python pendant logic problems
On the 7I96S there are 4 MPG channels built in with any standard firmware
These use the isolated inputs 0..7 but do not interfere with normal input use.
The count pins on the isolated I/O are:
hm2_7i96s.0.inm.00.enc0-count
hm2_7i96s.0.inm.00.enc1-count
hm2_7i96s.0.inm.00.enc2-count
hm2_7i96s.0.inm.00.enc3-count
There is also 7I96S firmware that puts MPG encoders on P1:
7i96sd_mpgp1.bin
Its MPG encoder count pins on P1 are:
hm2_7i96s.0.inm.01.enc0-count
hm2_7i96s.0.inm.01.enc1-count
hm2_7i96s.0.inm.01.enc2-count
hm2_7i96s.0.inm.01.enc3-count
These are additional to the MPG inputs available on the isolated I/O
If you are using buttons/MPG on P1, theĀ 7i96sd_mpgp1.bin
is probably the best as it also uses the INM module so has built-in
debounce on all inputs.
7i96sd_mpgp1.bin
Last edit: 24 Sep 2025 00:09 by PCW.
The following user(s) said Thank You: unknown
28 Sep 2025 16:40 - 28 Sep 2025 16:41 #335509
As a first step, get the encoder counting so that you can see a "counts" pin incrementing when you turn the encoder.
There are a few ways to do this mentioned above, and there is always the possibility of using the software encoder counter too, connected to GPIO pins,
Once you have the counts HAL pin working, that then needs connecting to all the axis (and joint) jog-counts pins. You then wire the switches to set the jog-enable pins of the axes/joints as required,
For the actual pin names see:
linuxcnc.org/docs/stable/html/man/man9/m...n.9.html#AXIS%20PINS
linuxcnc.org/docs/stable/html/man/man9/m....9.html#JOINT%20PINS
And possibly linuxcnc.org/docs/stable/html/man/man1/h...html#Joint%20jogging
But prefer the pins in "motion" to those in "halui" as the former run in realtime and so are more dependable.
Last edit: 28 Sep 2025 16:41 by andypugh.
Time to create page: 0.109 seconds
