Linear Move Exceeds Lower Limit
- scsmith1451
- Thank you received: 3
19 Sep 2025 18:50 #335197
by scsmith1451
Linear Move Exceeds Lower Limit was created by scsmith1451
I am trying to create a simple subroutine to surface a block before engraving. It originally complained about an EOF in the file so I decided to execute each move command individually using MDI to make sure the code was correct.
Here the snippet that is giving an error:
G0 X2.144 Y-0.125 (Move to start)
G0 Z-0.02 (Lower spindle)
G91 (Relative Moves)
G0 X-11.163 (Make cut)
G90 (Absolute Moves)
G0 Y1.6921 (Move Y for next cut)
-- -> G0 X11.163 (Make cut) <---
G0 Y3.5092 (Move Y for next cut)
G0 Z0.1 (Move to safe height)
At the line indicated ---> <--- LCNC reports an error to the effect that Linear Move will exceed limits of the machine. The program zero is located at the right-front corner of the block. Since I could move to the starting location in line 1 and do the first cut to "G0 X-11.163" which is negative, I naively expected moving opposite direction the same distance would be acceptable.
The block, 3.25 x 7.00 in., is located in the center of the 19 x 11 in. table with ample space on all sides for the 2 in. surfacing mill to clear the block. Fortunately, this was my first attempt to use LCNC on this machine so I was cutting air for the test, so no material was damaged.
Can someone help explain the error and how to resolve it?
Kind Regards,
Kind Regards,
- thanks for the help
20 Sep 2025 23:59 #335231
by thanks for the help
Replied by thanks for the help on topic Linear Move Exceeds Lower Limit
I am by no means an expert...novice at best...
Am I assuming correctly that the 19 on you table is the x direction and the y is 11? If so, is the 3.25 orientation of your block parallel with the x or the y? In your ini file are the limits set correctly?
Again I am such a rookie to this, just trying to help....
Good luck
Good luck
The following user(s) said Thank You: tommylight, unknown
- unknown
- Thank you received: 323
21 Sep 2025 01:47 #335233
by unknown
Replied by unknown on topic Linear Move Exceeds Lower Limit
I was wondering regarding about touch off relative to home. Do you have homing switches or have you been lazy like myself and not fitted them yet ? I home to marks on the table and column. Yeah I know I should lift my game.
21 Sep 2025 16:21 #335244
Yeah, I have home and limit switches. They came with the machine, so I was able to wire them in the control board.
- unknown
21 Sep 2025 17:03 #335245
by unknown
That's nice mate, but my reply was to the OP.
21 Sep 2025 17:12 #335246
oops....sorry.
- scsmith1451
21 Sep 2025 20:52 #335250
by scsmith1451
Replied by scsmith1451 on topic Linear Move Exceeds Lower Limit
Your assumptions are correct for both the table and the block.
- scsmith1451
21 Sep 2025 20:55 #335251
by scsmith1451
I have my machine configured for both and home on all axes.
- unknown
22 Sep 2025 04:06 #335262
by unknown
If you are able a willing to attach your hal & ini files (and any other hal files you may being using) it may be possible to run a sim of your config.
BTW what version of Linuxcnc are you using ?
- scsmith1451
22 Sep 2025 21:24 #335305
by scsmith1451
Out of frustration, I removed the o<word> declarations from the file and loaded the file as a normal g-code program. It worked correctly, start to finish. What ever was happening, mysteriously evaporated.
Thanks for your input and consideration.
