Linear Move Exceeds Lower Limit
1 year 1 month ago #335250 by scsmith1451
Your assumptions are correct for both the table and the block.
1 year 1 month ago #335251 by scsmith1451
I have my machine configured for both and home on all axes.
1 year 1 month ago #335262 by unknown
If you are able a willing to attach your hal & ini files (and any other hal files you may being using) it may be possible to run a sim of your config.
BTW what version of Linuxcnc are you using ?
1 year 1 month ago #335305 by scsmith1451
Out of frustration, I removed the o<word> declarations from the file and loaded the file as a normal g-code program. It worked correctly, start to finish. What ever was happening, mysteriously evaporated.
Thanks for your input and consideration.
1 year 1 month ago #335306 by unknown
Might have helped if you mentioned this to begin with. You really wasted a lot of people's time not giving the whole story.
Time to create page: 0.123 seconds
