Going from Devian 10 to 12 has created problems
- Hakan
- Thank you received: 453
25 Sep 2025 11:35 #335408
by Hakan
Replied by Hakan on topic Going from Devian 10 to 12 has created problems
Surely you can have that document as an attachment?
- jcbryant
25 Sep 2025 13:52 #335412
by jcbryant
Replied by jcbryant on topic Going from Devian 10 to 12 has created problems
"As I said 2 cores may not be enough anymore"
Why does Microsoft come to mind here? Doubtless the folks at Debian would say that Bookworm is an improvement on Buster, but I'd question how a system that may require more advanced hardware to do exactly the same job can be called an "improvement". I'm quite happy with my little industrial PC. It's a perfect fit for my workshop environment (small, fanless) and experience has proved that it is quite capable of running Linux CNC. So to my mind the problem is not my PC but Bookworm, and if all else fails I'm going to simply revert to the Linux 2.8.2 Buster distribution and accept that my system will have to stand pat as the Debian world moves on. End of rant.
- Thank you received: 5309
25 Sep 2025 15:24 #335415
Replied by PCW on topic Going from Devian 10 to 12 has created problems
It's more of a kernel/driver issue than hardware/Linux Distribution issue.
Are you using isolcpus?
- jcbryant
25 Sep 2025 16:39 #335416
by jcbryant
Yes, isolcpus is set to 1.
I think that the ping test is a smoking gun. If the results can be explained and a solution found I suspect (hope?) that everything else will fall into place. The attached is typical:
It's beyond belief that a round trip that typically takes about 0.1 ms can sometimes take 26ms. And note that the round trip clearly took more than 1ms quite a few times (the total test took more than the 60027ms it would have taken had there just been one bad ping). What could possibly be causing this to happen? It's not as if anything else was going on - apart from the test the computer was essentially idling.
I've paid my $2 Australian and have had a crack at IRQ affinity. But the solution proposed in the forum piece is of absolutely no use to me. irqbalance was not even active on my machine, and when I tried to install it it would not activate because the condition "CPUs=>1" was not met. Which does make sense - if you've only got two CPU's and you're not going to allow interrupts on one of them there isn't much scope for balancing. In practice interrupts are distributed between the two CPU's (note: they are evidently NOT excluded from the isolated CPU). See the attached file.
Presumably my goal should be to tie interrupt 29 with CPU 1 and all other interrupts with CPU 0. But how can this be achieved? I don't even have a /proc/irq folder, and even if I did I suspect that in the absence of irqbalance creating appropriate files wouldn't do me any good. And presumably I should also be running the ping test on the isolated CPU. Does the 99 priority force this to happen, or is something else required?
25 Sep 2025 17:07 #335417
You might try this script to pin the Ethernet interrupt to the last CPU
chmod +x pinirq.txt
sudo ./pinirq.txt enp1s0
(might also be enp1)
chmod +x pinirq.txt
- jcbryant
25 Sep 2025 17:27 #335418
by jcbryant
For what I want to do, the script boils down to
echo 2 > /proc/irq/29/smp-affinity
I've tried this and it doesn't work. I get "permission denied" (whether or not I use sudo), presumably because folder irq don't exist. And even if I were to create folder irq, and create a folder 29 within it, I can't see how just creating a file is going to change anything. Something has to use the file, and in this case I think that that something is irqbalance, which as I've mentioned doesn't exist and can't be made to exist.
25 Sep 2025 18:44 #335423
What does my script do?
(sudo is a bit funny with some command lines)
- Thank you received: 4140
25 Sep 2025 19:36 #335427
One of the issues here is that there is no RT ethernet drivers. Ethercat gets around this by writing their own drivers but for the most part now depends on the generic ethercat driver which is not real time which they say is mostly good enough (except for some realtek).
The only other trick which has worked with 2 core PC's in the past is to compile the kernel yourself because Debian seems to make some odd choices in their kernel version. If you go down this path, I would download the 6.1.17 kernel source and the matching 6.1.17 RT patch. I would do this to build a Deb on another PC with more cores or it will take you many hours/ even days. Perhaps PCW can provide some guidance on the necessary steps. Unfortunately, I have lost my scripts....
Replied by rodw on topic Going from Devian 10 to 12 has created problems
I think the world has got more complex and there are standards like energy efficient Ethernet (EEE) that the kernel has to support today in this world of power conservation. they all add up.rtt min/avg/max/mdev = 0.100/0.114/26.854/0.321 ms, pipe 2 As you say it is sometimes slow. This can be affected by the initial ping when its connecting but it can be EEE kicking in. Check the doc for how to disable that. (I am not convinced that it is still disabled by default.It's more of a kernel/driver issue than hardware/Linux Distribution issue.
25 Sep 2025 19:46 #335428
Ooops, I got that wrong go for kernel 6.16
25 Sep 2025 20:14 #335431
Here's a script for 6.17-rc1-rt1 that works for me on Mint 22.1
There may well be different dependencies on your system
unzip, chmod +x then sudo
And yes, Debian does seem to have a talent for making awful RT kernels
Time to create page: 0.300 seconds
