8i20 power supply variation.
- M4MazakUser
- Thank you received: 7
24 Sep 2025 01:06 #335348
by M4MazakUser
8i20 power supply variation. was created by M4MazakUser
After many -many many hours of having problems with random following errors in finally have found something that links.
so, when it's not sunny outside the voltage i read on the 8i20 card is 315v dc. When the sun is in full swing it reads 325v dc. This doesn't seem to relate to anything I know, but I have no errors when the sun isn't doing much, and plenty when it is, I'm thinking that there is probably some induced ripple from our solar system, and the dodgy fanuc power supply im using probably has a bad cap. Any ideas ???
- Thank you received: 5329
24 Sep 2025 03:05 #335350
Replied by PCW on topic 8i20 power supply variation.
Ripple should not make too much difference, you might plot the bus voltage in halscope
to see if there's anything suspicious.
- unknown
- Thank you received: 323
24 Sep 2025 03:09 #335351
by unknown
Replied by unknown on topic 8i20 power supply variation.
I'd look at a component heating issue first. Maybe just below "bad things" when it's not sunny outside, and pushed over the edge when it's sunny outside.
TBH honest the sun is huge, like really huge current thinking has it at 99.8% of the TOTAL mass of the solar system, all the planets and sundry matter make up 0.2% of the solar system (and our sun isn't all that big). And whether it's sunny or not outside it's still fusing ~600 million tonnes of Hydrogen per second into ~596 million tonnes of helium, thus fusing continues (element by element) until all that is left is iron, then we die, and being twisted by magnetic fields and the rest. So basically it's always on, doing what the sun does best fussing atoms into other atoms, generating heat and all manner of electromagnetic radiation.
I'm pretty sure if the ripple was being caused by the solar system you'd be noticing many many more items playing up.
But if you really want to check on the cosmic microwave background grab an old CRT tv, turn it on and turn to a channel that has no terrestrial signal, it'll give a reasonable idea of the radiation around. That's what a small part of the static is.
- M4MazakUser
24 Sep 2025 04:06 #335352
by M4MazakUser
Replied by M4MazakUser on topic 8i20 power supply variation.
I'm thinking more it's a bad filter cap and a rough infeed from the 3phase fronius solar inverter. It does bump the voltage up.
- unknown
24 Sep 2025 05:54 #335353
by unknown
Hahaha I look stupid, I thought "our solar system" you meant the solar system, some kind of weird google translation. Not a solar inverter as mentioned later.
You have my permission to make as much fun at my expense as you feel necessary. I honestly feel I deserve it.
Sorry if you thought I was making fun of you. Please accept my apologies.
The following user(s) said Thank You: M4MazakUser
- M4MazakUser
27 Sep 2025 08:49 - 27 Sep 2025 08:51 #335481
by M4MazakUser
I'm waiting for some parts to turn up, going to build a power supply- three phase rectifier and 4 large caps, the fanuc one I've been using is basically a bridge rectifier I'm not sure how good the caps are, if I power it up it displays a fault code. It has been 2metres under floodwater (two washing machines in 'merican speak). So i don't really trust it. The issues I have are during hard acceleration from stopped, or high speed travel(rapid moves). Say I'm moving an axis 8in - 200mm, it will throw an error at around the 7in mark, this i can fix if I lower the travel speed a bit. I never lose encoder position but I geuss the mesa cards have that under control. I would have preferred an Ethernet style card, but not much was available during covid etc. I don't believe the computer is the issue from tests I've done and the bios settings in place etc. It never shows any errors about realtime etc.
Last edit: 27 Sep 2025 08:51 by M4MazakUser.
Time to create page: 0.525 seconds
