lcec and Operation not permitted
- Ri
When running the configuration, such errors occur:0 0:0 OP + 2DM880-EC
1 0:1 OP + 2DM880-EC
2 0:2 OP + 2DM880-EC
3 0:3 OP + 2DM556-EC
4 0:4 OP + 2DM556-EC
5 0:5 OP + DIEWU EtherCAT-IO (Digital 16-Input/16-Output)
I tried to fix the access error:Debug file information:
Note: Using POSIX realtime
HAL: ERROR: duplicate thread name servo-thread
THREADS: ERROR: could not create thread 'servo-thread'
threads: rtapi_app_main: Operation not permitted (-1)
./Sodick.hal:20: waitpid failed /usr/bin/rtapi_app threads
./Sodick.hal:20: /usr/bin/rtapi_app exited without becoming ready
./Sodick.hal:20: insmod for threads failed, returned -1
shutdown.hal:4: parameter or pin 'lcec.0.0.enable' not found
3184
Stopping realtime threads
Unloading hal componentsNote: Using POSIX realtime
And all lcec files installed from linuxcnc:groups
sodick lp dialout cdrom sudo audio video plugdev users ethercat linuxcnc ecusers realtime
/usr/bin/lcec_configgen
/usr/bin/lcec_conf
/usr/lib/linuxcnc/modules/lcec.so
/etc/linuxcnc/lcec.conf
Hal file:
# Загрузка EtherCAT компонента
loadusr -W lcec_conf /home/sodick/linuxcnc/configs/Sodick/ethercat-conf.xml
loadrt lcec
# Загрузка дополнительных HAL компонентов
loadrt siggen
loadrt or2
loadrt and2
loadrt not
# Создание thread с уникальным именем
loadrt threads name1=servo-thread period1=1000000 fp1=0
# Добавление функций в поток (правильный порядок)
addf lcec.0.read servo-thread
addf lcec.read-all servo-thread
addf lcec.write-all servo-thread
addf lcec.0.write servo-thread
- Thank you received: 7488
Seems like trying to load servo period twice, so try omitting the above line.# Создание thread с уникальным именем
