INI and HAL files
- Twitchy88
- Thank you received: 4
11 Oct 2025 23:26 #336303
by Twitchy88
INI and HAL files was created by Twitchy88
Hello
Can someone give me a quick run down of the INI and HAL files. I successfully got an axis on my Fadal mill moving today with mesa 7i96s and DMM Dyn4 servos using axis. I used PNCCONF and it still wouldn't work, then I realised the files needed to be put somewhere but for the life of me I couldn't figure out what files needed to go where. After watching a video I saw the button to "create desktop launcher to start linux with this configuration".
I would like to learn how to modify the files manually and put them where they need to go. If I were to start from scratch without PNCCONF what files need to be modified and put where?
- Online
- Thank you received: 7478
11 Oct 2025 23:50 #336305
Replied by tommylight on topic INI and HAL files
/home/cnc/linuxcnc/configs/
Notice cnc is the user name so it will be whatever user name you have on that PC.
And it does not matter at all where the config files are, as long as they are readable and have no spaces in the name (this was an issue way way before, no idea if still true).
You can have configuration files on a USB stick or network share or ... and still they can be run and used to control the machine.
For editing the config files, never ever use windows or office suits, use only simple text editors like xed or gedit or geany or nano or vim.
Use the PncConf wizard, it can do pretty much everything needed, and it can also edit the created configs.
Another thing, you can have multiple configs for the same machine with different setups, so make as much as you like till you get things working as you like them to.
The following user(s) said Thank You: Twitchy88
- Twitchy88
12 Oct 2025 13:32 #336323
by Twitchy88
Replied by Twitchy88 on topic INI and HAL files
I feel like I am going to have to modify the files manually, to get the automatic tool changer working, and setting up things like servo drive enable, alarm input, estop, high and low speed on the spindle.
I could be wrong, very new to this.
- Thank you received: 4654
12 Oct 2025 17:01 #336337
Replied by andypugh on topic INI and HAL files
Yes, all those things will need manual HAL edits.
You don;'t have to put everything in the same file, the [HAL] section of the INI can pull in as many .hal files as you need. It may make sense to have the toolchanger in a separate file, for example.
You can also have several INI files in the same config folder, sharing HAL files, tool table, etc. This can be handy if, for example, you have a part-time rotary axis, or an alternative geaometry. (for example my mill has a horizontal spindle that I sometimes use, and that means swapping the Z and Y axes.)
I might be worth skim-reading the list of available HAL components to get a feel for what is available. You are likely to need the "carousel" component, for example.
linuxcnc.org/docs/stable/html/
Scroll down to (and expand if necessary):
Commands and userspace components
Realtime components and kernel modules
- Twitchy88
13 Oct 2025 11:45 - 13 Oct 2025 11:46 #336373
by Twitchy88
Thank you!
I got carousel and looked through it quick.
So my understanding is the machine has a main INI file and HAL file. The INI file pulls in the HAL files that are to be used. HAL files connect real world things to hardware, hardware to hardware and anything virtual?
What file actually dictates how the machine moves for carousel, and what language would it be programmed with? Im an industrial electrician that programs with ladder.
Last edit: 13 Oct 2025 11:46 by Twitchy88.
16 Oct 2025 12:07 #336539
If you like ladder, then you can use that for your toolchanger.
(Though it isn't easy to program axis movements from Ladder)
linuxcnc.org/docs/stable/html/ladder/ladder-intro.html
linuxcnc.org/docs/stable/html/ladder/classic-ladder.html
linuxcnc.org/docs/stable/html/ladder/ladder-examples.html
I normally suggest controlling a toolchange sequence with G-code. It is a terrible programming language but does have built-in behaviour for moving axes around, for setting HAL pins, and for waiting for the state of HAL pins to change (with timeout).
See the example G-code routine here (which works in conjunction with the carousel.comp)
github.com/LinuxCNC/linuxcnc/blob/master...hange/toolchange.ngc
You can run that whole config (it's a simulator with a graphical representation of a milling machine) by starting LinuxCNC and picking the sim/axis/vismach/vmc_toolchange config and picking one of the two INI files
(this is also an example of two configs sharing HAL and support files, the configs deomnstrate two different types of tool carousel position feedback)
Time to create page: 0.120 seconds
