Why are there 3 2.9.2 ISO files?
  • langdons
  • langdons's Avatar Topic Author
  • Platinum Member
  • Platinum Member
13 Oct 2025 00:58 - 13 Oct 2025 01:29 #336355 by langdons
Why are there 3 2.9.2 ISO files? was created by langdons
There's this one:
linuxcnc.org/iso/LinuxCNC_2.9.2-amd64.hybrid.iso
And this one:
linuxcnc.org/iso/linuxcnc_2.9.2-amd.hybrid.iso
And this one too:
On my mirror, www3.langdonstaab.ca/iso, I would like to remove these likely duplicates to reduce bandwidth and load for my server in the event that someone downloads all the files on my server (with wget -r or something).
Are these files identical?
Why are they still there?
Which one is actually correct?
Last edit: 13 Oct 2025 01:29 by langdons. Reason: Fixed mirror link.
  • Pablado
  • Pablado's Avatar
  • Visitor
  • Visitor
14 Oct 2025 02:56 #336407 by Pablado
Replied by Pablado on topic Why are there 3 2.9.2 ISO files?
There's this one:
And this one:
And this one too:
They should be identical builds, but sometimes the project keeps multiple copies for mirror syncing or testing purposes. You can check the file hashes (MD5 or SHA256) to confirm before removing any duplicates from your mirror.
  • Moderator
  • Moderator
14 Oct 2025 12:52 #336425 by tommylight
Replied by tommylight on topic Why are there 3 2.9.2 ISO files?
Keep only the latest ISO and maybe the Wheezy for users of parallel port machines, delete everything else.
  • langdons
  • Platinum Member
  • Platinum Member
14 Oct 2025 23:31 #336462 by langdons
Replied by langdons on topic Why are there 3 2.9.2 ISO files?
I deleted all other files.
(And fixed the directory structure!)
Now it's just wheezy and 2.9.4.
  • langdons
  • Platinum Member
  • Platinum Member
14 Oct 2025 23:38 #336463 by langdons
2.9.4 and Wheezy now accessible via:
www3.langdonstaab.ca/LinuxCNC/
www3.langdonstaab.ca/LinuxCNC/iso/
and
www3.langdonstaab.ca/iso/
Random Ubuntu Server question:
Why does the du command show the symbolic link (created via ln) as occupying space and not the actual file?
Really strange.
