PP problem versions 2.9.5 and 2.9.6
- COFHAL
- Thank you received: 62
15 Oct 2025 02:08 #336468
by COFHAL
PP problem versions 2.9.5 and 2.9.6 was created by COFHAL
I installed both versions 2.9.5 and 2.9.6 and both have the same problem with the parallel port. I have an MPG configured with a C10 and in version 2.9.4 it works perfectly, but in either of these last two versions it doesn't. When running LCN you can see with the hal that the parallel port is indeed loaded on the pins, but none of the functions programmed in the MPG work. I went back to 2.9.4 and the MPG works again.
- Thank you received: 2164
15 Oct 2025 05:08 #336473
Replied by Aciera on topic PP problem versions 2.9.5 and 2.9.6
Might be related to this:
github.com/LinuxCNC/linuxcnc/issues/3583
Time to create page: 0.098 seconds
