Is there a new Linuxcnc release in the wings ?
15 Oct 2025 21:21 #336517 by unknown
Referencing this post forum.linuxcnc.org/29-forum-announcement...-9-6-released#336514 is there a possibility of a 2.9.7 release or something along those lines.
The reason I ask as I have been working on trying to create an ISO that doesn't suffer from the "raspi-firmware" issue. And I would like to have a dialogue with regards to releasing a 2.9.x ISO.
15 Oct 2025 22:44 #336523 by unknown
Certainly seems that way.
Aciera literally stated there would be another release, did he not?
But when?
Not helpful, I was looking for a definite answer. Not the words of someone whose words soothe them.
15 Oct 2025 23:54 #336526 by andypugh
Replied by andypugh on topic Is there a new Linuxcnc release in the wings ?
Well, the only person who knows for sure is the release manager.
And he thinks that a 2.9.7 is very likely given that one of the fixes in 2.9.6 broke the WHB... pendant driver.
But he is also looking at an ISO based on Trixie, but that will need a new archive signing key as the current one is considered too short.
Please submit your work as pull requests to the "official" ISO building repository rather than going off on your own with this.
The following user(s) said Thank You: tommylight,
16 Oct 2025 00:38 - 16 Oct 2025 01:22 #336530 by unknown
@Admins
I feel I overstepped my position and would like this topic deleted.
Last edit: 16 Oct 2025 01:22 by unknown.
16 Oct 2025 17:08 #336557 by Hakan
But Andy does have a good point, doesn't he? It would be much better if this was fixed in the official linuxcnc distribution.
Perhaps you can open an issue at linuxcnc github and see it you can get your fixes incorporated?
16 Oct 2025 23:36 #336578 by unknown
That doesn't always happen.
I used to distribute an ISO based on Mint 19.x & build packages for installation via apt.
Tommy has a later Mint based ISO, if memory serves me right.
There has been a couple of Raspi OS based images for the RPi platform as opposed to the Debian based image that forms the official image.
The code base used to build the current image is a fork from the linxcuc live-build repo.
In another thread I posted links to test images, based on my findings regarding the raspi-firmware issues, unfortunately no one, it would seem, downloaded and was able to test the images. It was clearly stated that they were test images only and not to be used for a production machine.
I did state in my initial thread that I wanted to open a dialogue with regards to building a new 2.9.x based ISO.
Machine Kit was a fork of Linuxcnc, worked well on a lowly powered BeagleBoneBlack (1Ghz & 512MB ram) and was able to use the in built micro controller for step & direction generation worked quite well on a 3 axis mill, unfortunately development on that project stalled.
@langdons "not some random offshoot side project fork" . Oh the irony.
17 Oct 2025 12:28 #336591 by unknown
Say for instance I was experimenting with building an ISO based on Trixie and found that some packages in the bookworm build aren't in the Trixie repo and
A: there is a another package that provides the same function
B: there is no equivalent for Trixie
C: a package appears to be confusing as to why it's been included
D: some packages I think maybe an idea to include
E: a file may not needed to be included
What would be the ideal way to communicate these.
BTW for the time being I had to make a temporary change to be able to install packages from the Linuxcnc repo due to the key issue.
The build was just out of curiosity to see how things go and I thought if I found anything that needed changing it may help later down the track.
I'm unsure if a pull request is the correct way to go. I apologise but my GitHub knowledge is more or less at a toddler stage.
17 Oct 2025 16:00 #336605 by tommylight
Replied by tommylight on topic Is there a new Linuxcnc release in the wings ?
A: is it open source?
B: not even on backports?
C: never a good idea
D: List?
E: what file was included ?
17 Oct 2025 17:30 - 17 Oct 2025 17:32 #336614 by unknown
Everything has been pretty well documented within the package lists and in the commit messages.
I thought a backport would be a package that is in eg Trixie that was been repackaged for Bookworm.
TBH the extra packages may be pulling in too much extra stuff, the ISO weighs in at about 4.1G, which I think is due to suggested packages being installed as well. And TBH I've only included them to make transferring files around a little easier whilst testing. Like I said it's experimentation ATM, whether it's any use upstream I don't know.
Not even going to bother to upload to Google drive and ask for any help testing as it was a waste of time. I guess people are busy.
Last edit: 17 Oct 2025 17:32 by unknown.
18 Oct 2025 01:18 #336643 by unknown
Yes.
The mk mailing list just receives spam, I haven't seen any actual activity for a while.
The Github repos, even the repos that they split, (long story if you want more info on that you will have to read the repos), haven't had any activity for a long time.
Time to create page: 0.111 seconds
