Terminated with an error, I'm begging for help
- PanikEspoir
17 Oct 2025 15:37 #336603
by PanikEspoir
Terminated with an error, I'm begging for help was created by PanikEspoir
I know basically nothing about code. The program will not start. I don't know where else to look for help.Not that you care and not to be dramatic, but my father is recovering from a bad car crash and I need to keep the business going.Print file information:RUN_IN_PLACE=noLINUXCNC_DIR=LINUXCNC_BIN_DIR=/usr/binLINUXCNC_TCL_DIR=/usr/lib/tcltk/linuxcncLINUXCNC_SCRIPT_DIR=LINUXCNC_RTLIB_DIR=/usr/realtime-3.4-9-rtai-686-pae/modules/linuxcncLINUXCNC_CONFIG_DIR=LINUXCNC_LANG_DIR=/usr/share/linuxcnc/tcl/msgsINIVAR=inivarHALCMD=halcmdLINUXCNC_EMCSH=/usr/bin/wish8.5LINUXCNC - 2.7.0Machine configuration directory is '/home/router/linuxcnc/configs/RMM0705HZ'Machine configuration file is 'RMM0705HZ.ini'INIFILE=/home/router/linuxcnc/configs/RMM0705HZ/RMM0705HZ.iniPARAMETER_FILE=linuxcnc.varTASK=milltaskHALUI=haluiDISPLAY=axisStarting LinuxCNC...Starting LinuxCNC server program: linuxcncsvrLoading Real Time OS, RTAPI, and HAL_LIB modulesStarting LinuxCNC IO program: ioStarting HAL User Interface program: haluiFound file(REL): ./RMM0705HZ.halShutting down and cleaning up LinuxCNC...Running HAL shutdown scriptKilling task linuxcncsvr, PID=4735Removing HAL_LIB, RTAPI, and Real Time OS modulesRemoving NML shared memory segments Debug file information:./RMM0705HZ.hal:30: Pin 'hm2_5i25.0.7i76.0.0.input-00' does not exist4735 PID TTY STAT TIME COMMANDStopping realtime threadsUnloading hal components
- Thank you received: 7478
17 Oct 2025 15:52 #336604
Replied by tommylight on topic Terminated with an error, I'm begging for help
From your error logDoes the 7i76 have field power connected?
The following user(s) said Thank You: PanikEspoir
- PanikEspoir
17 Oct 2025 16:20 #336611
by PanikEspoir
Replied by PanikEspoir on topic Terminated with an error, I'm begging for help
It has two little lights on
- Thank you received: 5325
17 Oct 2025 17:19 #336613
Replied by PCW on topic Terminated with an error, I'm begging for help
Were any changes made in the machine?
If you have both Yellow LEDs illuminated, that means power is probably OK
Other possible issues:
1. Cabling from the 5I25/6I25 to the 7I76
2. 7I76 Field voltage too low (check with a voltmeter)
3. Jumpering changed? (correct = 7I76 W1 and W3 LEFT)
4. Bad 5I25/6I25 or wrong firmware (again was anything changed?)
5. Bad 7I76
5. Bad 7I76
- PanikEspoir
17 Oct 2025 18:05 #336616
by PanikEspoir
There were some electric issues due to an electric storm.
Thanks for the reply.
Time to create page: 0.101 seconds
