burning iso to USB drive
19 Oct 2025 15:10 #336707 by clayton2ndtry
burning iso to USB drive was created by clayton2ndtry
My antique Dell Optiplex does not boot from CDROM anymore.  LinuxCNC 2.9.4, which has worked beautifully for many months, is now hanging the PC.  I attempted to use Package Manager to reinstall it.  It fails.  I tried to uninstall it.  It fails, so I guess that I need to reinstall from a USB drive, which is how I installed the now Zombie version.  I do not remember how I burned the ISO to USB drive from Windows.  ImgBurn only burns to CDROM drives.  Rufus does not give me a way to select a USB drive.  Help!
19 Oct 2025 18:12 #336719 by tommylight
Replied by tommylight on topic burning iso to USB drive
What model of OptiPlex ?
19 Oct 2025 20:09 #336725 by clayton2ndtry
Replied by clayton2ndtry on topic burning iso to USB drive
9660. The DVD drive fails BIOS diagnostics. Spindle error. I am ordering a replacement drive. In the meantime, I used a USB DVD drive. The 2.9.2 disk would not boot. But an ancient disk from Sherline called EMC2 did boot and install from that USB DVD drive. This is so ancient that Update Manager does not work. I put 2.9.4 on the DVD. While trying to install, it complained about unmounting media failing. I suspect 2.9.4 ISO lacks the smarts to handle a USB DVD drive. I have successfully installed 2.7.14 before so that is next.
20 Oct 2025 01:23 #336733 by unknown
Replied by unknown on topic burning iso to USB drive
Use win32diskimager.org/ to write the ISO to the USB drive. It's dumb in the way it will just write byte by byte and not try to do anything fancy.
20 Oct 2025 12:42 #336747 by clayton2ndtry
I downloaded win32diskimager but it has no place for specifying the ISO file. This is no open button.
20 Oct 2025 20:03 #336769 by unknown
21 Oct 2025 11:16 #336813 by rodw
Replied by rodw on topic burning iso to USB drive
win32diskimager was my go to for years but it has let me down with later versions. I recommend you use Balena Etcher which is available for Windows, Linux and Mac.
I discussed its use in my latest video
The following user(s) said Thank You: unknown
Time to create page: 1.117 seconds
