Can't issue MDI command when not homed
21 Oct 2025 13:23 #336828 by clayton2ndtry
Can't issue MDI command when not homed was created by clayton2ndtry
I have recently had to return to 2.7.15 from 2.9.4.  (There is no easy way to upgrade from 2.7.15 to 2.8 which is required to get to 2.9.4.  Attempts to install from 2.9.4 ISO were unsucessful.  Even getting 2.7.15 to install from ISO was hard,)
This all worked fine in 2.9.4.  In axis gui, I have homed all four axes.  Z=0.  When I use G1 Z1 f4, I get "Can't issue MDI command when not homed."  Can you tell me what I need to fix?
21 Oct 2025 13:36 #336829 by clayton2ndtry
Replied by clayton2ndtry on topic Can't issue MDI command when not homed
Fixed.
Time to create page: 0.137 seconds
