Thanks, all.
In general, I like the Ethernet solution, especially because it comes with a built-in galvanic isolation.
What I dislike is, that this more or less rules out all notebook solutions, bc I need a network connection.
From what I experienced, but maybe it was all just bad luck, is that all internal WIFI connections do not work,
except for a couple of devices with a PCMCIA wireless card. I did not try every possible combination, but also
USB to Ethernet adapters seem to have a severe impact on latency.
Is my 7i91 too old maybe?
Of course, I set up everything with the help of pncconf and used the default settings wherever possible.
I had latency (network) test running for days without issues; I programmed a Python script to let the A/B tables
rotate for hours flawlessly; but five minutes of probing and error - one real longer milling job and joint error.
I spent hours in front of the HAL scope, just to catch this magic moment. I even had a camera recording it.
Nothing was caught in flagranti.
I now, just for fun, developed a USB to SPI MCU board and started to mod some of the LinuxCNC SPI
code for the 7c81. Not sure yet if isochronous transfer is possible or interrupt transfer would clog everything.
This would be my preferred (notebook) solution.
Which computers are you using for the 7i91? Whenever I browse through all of this here, I only see
10+ years old systems at work (like tommylight’s Thinkpad collection, hehe).
What about a top modern one?
And just to make sure, you all mean PREEMPT-RT, right? Not RTAI.
