motion.so not found error ...
1 year 10 hours ago - 1 year 10 hours ago #337666 by MusicCityMfg
I have installed LinuxCNC ver 2.9.7 including linuxcnc-uspace. LinuxCNC seems to be running fine.
I'm trying to learn HAL and coded "loadrt motion" in my playground HAL file.
When I open my playground config in LinuxCNC, I keep getting the error: "motion: dlopen: /usr/lib/linuxcnc/modules/motion.so: cannot open shared object file: No such file or directory"
When I run "dpkg -l | grep linuxcnc", I see: "ii  linuxcnc-uspace  1:2.9.7  amd64 motion controller for CNC machines and robots"
When I view the "/usr/lib/linuxcnc/modules" directory there is a "motmod.so" file but no "motion.so" file.
It is my understanding that motmod.so was part of LinuxCNC v2.8 and older and motion.so is part of LinuxCNC v2.9 and up.
I am a new to and just learning LinuxCNC as I prepare for a manual lathe CNC conversion.
Am I doing something wrong? Is there an issue with my LinuxCNC install?
Thanks!
Last edit: 1 year 10 hours ago by MusicCityMfg.
1 year 10 hours ago #337668 by rodw
Replied by rodw on topic motion.so not found error ...
All the Sims work on 2.97 so I suspect the issue is in your hal file. share it and we can look or compare with one of the Sims.
The following user(s) said Thank You: MusicCityMfg
1 year 10 hours ago - 1 year 10 hours ago #337669 by Hakan
Replied by Hakan on topic motion.so not found error ...
The name is motmod.so
Last edit: 1 year 10 hours ago by Hakan.
1 year 10 hours ago #337671 by Aciera
'motion' is not a hal component so you cannot and need not load it in hal.
1 year 10 hours ago #337672 by MusicCityMfg
Thank you, attached is my HAL file.
1 year 10 hours ago #337673 by MusicCityMfg
Thank you @Aviera and @Hakan! I will try that.
Time to create page: 0.387 seconds
