Help with Wireless Handwheel XHC-WHB04B-6 (wrong Product ID)
11 months 4 weeks ago #337807 by Gogonfa
Hi everyone,
I’m trying to get my XHC-WHB04B-6 wireless handwheel working with LinuxCNC, but mine shows up as:
Bus 001 Device 052: ID 10ce:[b]eb91[/b] Silicon Labs
So the Vendor ID (10ce) is fine, but the Product ID is 0xeb91 instead of the usual 0xeb93.
It’s one of those AliExpress clones, originally meant for EdingCNC controllers.
From what I’ve read, the Product ID is defined in the driver source (like usb.h), and you’d need to rebuild it — which I can’t manage.
Has anyone already patched this or found a way to make LinuxCNC recognize it?
Thanks a lot!
Michael
11 months 4 weeks ago #337815 by unknown
lspci will only probe devices on the pci\pcie bus.
The OP is correct the USB device ids are defined in the header file.
Maybe if the OP raised an issue on the GitHub page he would have direct access to the Devs.
Unfortunately the only thing I can think of is to follow the instructions given in the docs and build Linuxcnc from source as a RIP and see how things go.
11 months 4 weeks ago #337827 by Hakan
There may be more than the usb product code that differ between them.
Here is where to change  github.com/LinuxCNC/linuxcnc/blob/fb1480...-whb04b-6/usb.h#L311
Then build linuxcnc and run-in-place.
11 months 4 weeks ago #337828 by rodw
Linuxcnc 2.9.4 was released to fix some things with with XHC USB pendants. Perhaps an upgrade will fix things. Here is how to get it on Trixie
11 months 4 weeks ago #337832 by unknown
It's the IDs that are the issue which are hard coded into the driver. 2.9.7 won't help.
11 months 4 weeks ago #337835 by rodw
[b]From what I’ve read, the Product ID is defined in the driver source (like usb.h), and you’d need to rebuild it — which I can’t manage.[/b]
Anybody can build linuxcnc from source. I did a video guide.  studio.youtube.com/video/Oe4Hfq3G2_A/edit
Time to create page: 0.379 seconds
