Determining Rate Of Accelleration
11 Nov 2025 14:48 #338190 by TurboStreetCar
Determining Rate Of Accelleration was created by TurboStreetCar
Hello, i have a project im working on (Not a CNC machine, but i believe a Mesa card is good capable hardware for this application) where im trying to determine the rate of acceleration of an externally driven spindle using an encoder.
There doesn't seem to be any built in components for this that i can find.
The use case, is to feed the rate of acceleration into a PID loop to control the output of a stepper/servo that regulates the spindles speed.
Is there a relatively easy way to measure/determine rate of acceleration accurately?
11 Nov 2025 15:14 #338192 by PCW
Replied by PCW on topic Determining Rate Of Accelleration
You can get acceleration by taking  the derivative of the encoder velocity pin with the HAL ddt component.
13 Nov 2025 13:45 #338309 by TurboStreetCar
Replied by TurboStreetCar on topic Determining Rate Of Accelleration
Aha! I knew there had to be a relatively easy way. Thanks!
Time to create page: 0.071 seconds
