- Thank you received: 4
Program stopped - do not understand the cause
- kmeld
- Topic Author
11 months 3 weeks ago #338254
by kmeld
Program stopped - do not understand the cause was created by kmeld
I have a problem I am not able to figure out at all. So, I need some help.
I have simple 4 axis controller build on MESA 7i96S.
I have only stepper motors connected phisicaly. Forth controller is not connected.
I am running this machine fine for most of the time.
But sometimes I am getting this (error message in the right bottom of the screen):
"hm2/hm2_7i9666666s.0:Watchdog has bit (set the /has-bit.pin to False to resume)"
below this is second error message:
"Unexpected realitime delay on task 0 with period 1000000
This Message will only appear once per session.
Run the Latency Test and before continuing"
I find LinuxCNC in a state of e-stop and machine not running. But position where program is interrupted is not necsarely concistant with phisical position of the machine.
If I get controller from e-stop state jogginf works in the controller but machine does not move.
What can be the cause and nature of this problem?
Cris
Cris
- Thank you received: 5334
11 months 3 weeks ago - 11 months 3 weeks ago #338256
Replied by PCW on topic Program stopped - do not understand the cause
This indicates a loss of communication , most commonly this is a real time issue
with the network connection.
Typical fixes for network real time issues:
If you host computer uses a RealTek Ethernet chip, it's likely you need to install the DKMS 8168 driver.
If you have a Intel Ethernet chip, disabling IRQ coalescing helps (see hm2_eth manual page)
To tesl network latency, run this command:
sudo chrt 99 ping -i .001 -q -c 60000 [card_ip_address]
This will run for 1 minute and print timing statistics.
Where [card_ip_address] is the 7I96s card ip address (192.168.1.121 or 10.10.10.10)
Last edit: 11 months 3 weeks ago by PCW.
Time to create page: 0.038 seconds
