Debian Linuxcnc9, network boards xcarve
- rrhoten
15 Nov 2025 00:39 #338423
by rrhoten
Debian Linuxcnc9, network boards xcarve was created by rrhoten
Been using LinuxCNC for years without problem. Now, Linuxcnc loads but xcarve gives and error. Last line before load stops says it can't find network card. Is it referring to my wifi card or my mesa card? Don't know why it would need a network card.
- Ray -
- Ray -
- unknown
- Thank you received: 323
15 Nov 2025 03:15 #338438
by unknown
Replied by unknown on topic Debian Linuxcnc9, network boards xcarve
It would referring to the Ethernet interface which would allow the computer to connect to the mesa card.
As if all things, we are not mind readers, it is so so so very helpful to post the actual error log. There maybe more to it than you can see. It is also helpful to describe you hard ware as well, what PC if possible a link to the actual specs, the ypre of mesa card and so forth. Aslo whether your network card (wired = ethernet generally) is on board or a separate add in card.
- Thank you received: 4153
15 Nov 2025 03:30 #338442
Replied by rodw on topic Debian Linuxcnc9, network boards xcarve
usually when working systems break, something has broken. Its told you the error but you have not really told us.
Start at the beginning. can you ping your mesa card
The following user(s) said Thank You: unknown
- unknown
15 Nov 2025 07:17 #338447
by unknown
I'd go one step further and establish that the network card appears in lspci. And that it has an appropriate address.
But we can only speculate on how to fix this issue until more information is supplied by the OP.
Time to create page: 0.975 seconds
