Probe basic launch issue
- Tinker
- Thank you received: 3
18 Nov 2025 16:01 #338628
by Tinker
Probe basic launch issue was created by Tinker
I just tried to install probe basic and was able to but when i try to launch it i get the following error Traceback (most recent call last):File "/usr/bin/probe_basic", line 8, in <module>sys.exit(main())~~~~^^File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in mainqtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcprun(*args, **kwargs)~~~^^^^^^^^^^^^^^^^^File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in runlaunch_application(opts, config)~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 70, in launch_applicationapp = _initialize_object_from_dict(config)File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 205, in _initialize_object_from_dictobj = _get_object_by_referance(provider)File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 193, in _get_object_by_referancereturn getattr(importlib.import_module(modname), attrname)~~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^File "/usr/lib/python3.13/importlib/__init__.py", line 88, in import_modulereturn _bootstrap._gcd_import(name[level:], package, level)~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^File "<frozen importlib._bootstrap>", line 1387, in _gcd_importFile "<frozen importlib._bootstrap>", line 1360, in _find_and_loadFile "<frozen importlib._bootstrap>", line 1331, in _find_and_load_unlockedFile "<frozen importlib._bootstrap>", line 935, in _load_unlockedFile "<frozen importlib._bootstrap_external>", line 1026, in exec_moduleFile "<frozen importlib._bootstrap>", line 488, in _call_with_frames_removedFile "/usr/lib/python3/dist-packages/qtpyvcp/app/application.py", line 7, in <module>import impModuleNotFoundError: No module named 'imp'
p, li { white-space: pre-wrap; }
- Thank you received: 2176
18 Nov 2025 16:32 #338632
Replied by Aciera on topic Probe basic launch issue
The problem is that the 'imp' python module has been removed from newer versions of python, Code that use it should be ported to use 'importlib' instead.
There have been other reports about this. Since Probe Basic is an external project it might be worth filing this as an issue on their Github page:
github.com/kcjengr/probe_basic/issues
- Tinker
18 Nov 2025 16:48 #338633
by Tinker
Replied by Tinker on topic Probe basic launch issue
I posted it ti the gethub, hopefully they can help me get this thing going..
- unknown
- Thank you received: 323
18 Nov 2025 20:15 #338654
by unknown
Replied by unknown on topic Probe basic launch issue
I guess you're installing on Trixie.
Install
sudo apt install python3-zombie-imp
Then if you try to run you'll get another error which is related to libqt5quickwidgets5
sudo apt install libqt5quickwidgets5
Install
The following user(s) said Thank You: tommylight, COFHAL, Unlogic
- Tinker
21 Nov 2025 12:27 #338885
by Tinker
I installed the sugested files and now I am getting the following error report.
sys.exit(main())
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 78, in launch_application
loadWindows(config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 230, in loadWindows
window = _initialize_object_from_dict(window_dict)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 210, in _initialize_object_from_dict
return obj(*args, **kwargs)
File "/usr/lib/python3/dist-packages/probe_basic/probe_basic.py", line 35, in __init__
super(ProbeBasic, self).__init__(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 56, in __init__
self.loadUi(ui_file)
File "/usr/lib/python3/dist-packages/qtpyvcp/widgets/form_widgets/main_window.py", line 115, in loadUi
uic.loadUi(ui_file, self)
File "/usr/lib/python3/dist-packages/PyQt5/uic/__init__.py", line 241, in loadUi
return DynamicUILoader(package).loadUi(uifile, baseinstance, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/loader.py", line 66, in loadUi
return self.parse(filename, resource_suffix)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 1037, in parse
actor(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 828, in createUserInterface
self.traverseWidgetTree(elem)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 806, in traverseWidgetTree
handler(self, child)
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 273, in createWidget
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 503, in createLayout
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 546, in handleItem
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 264, in createWidget
self.stack.push(self.setupObject(widget_class, parent, elem))
File "/usr/lib/python3/dist-packages/PyQt5/uic/uiparser.py", line 228, in setupObject
obj = self.factory.createQObject(clsname, name, args, is_attribute)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 100, in createQObject
factory = self.findQObjectType(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/objcreator.py", line 125, in findQObjectType
w = module.search(classname)
File "/usr/lib/python3/dist-packages/PyQt5/uic/Loader/qobjectcreator.py", line 113, in search
module = __import__(mname, {}, {}, (cls,))
File "/usr/lib/python3/dist-packages/widgets/__init__.py", line 3, in <module>
from widgets.lathe_tool_touch_off.lathe_tool_touch_off import LatheToolTouchOff
File "/usr/lib/python3/dist-packages/widgets/lathe_tool_touch_off/lathe_tool_touch_off.py", line 19, in <module>
from qtpy.QtQuickWidgets import QQuickWidget
File "/usr/lib/python3/dist-packages/qtpy/QtQuickWidgets.py", line 13, in <module>
from PyQt5.QtQuickWidgets import *
ModuleNotFoundError: No module named 'PyQt5.QtQuickWidgets'
sys.exit(main())
loadWindows(config)
actor(elem)
- unknown
21 Nov 2025 12:35 #338887
by unknown
Sorry I may have given the wrong package.
Have a look at this one.
packages.debian.org/trixie/amd64/python3-pyqt5.qtquick
Many apologies I was working from memory and apparently my memory was corrupted. I apologise for any time wasted.
Regarding the python errors if yo get a ModuleNotFoundError you can search for the name of the module that is stated as missing .
- Tinker
21 Nov 2025 12:43 #338888
by Tinker
Sorry, I'm a total beginner when it comes to this stuff. I'm at the copy and paste stage and don't really know what I'm looking for on that link...Is there a specific package I should download?
- Tinker
21 Nov 2025 12:56 #338891
by Tinker
So I installed python3-pyqt5.qtquick and now it works !!!! Thank you sooo much!!
- Tinker
21 Nov 2025 15:01 #338900
by Tinker
So i was able to get PB to launch and then i tried to do the modifications that were recomended on the start screen. I modified my HAL and INI files and now have the following error report..
Error report created by /usr/lib/tcltk/linuxcnc/show_errors.tcl:
Print file information:
RUN_IN_PLACE=no
LINUXCNC_DIR=
LINUXCNC_BIN_DIR=/usr/bin
LINUXCNC_SCRIPT_DIR=
LINUXCNC_CONFIG_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
Machine configuration directory is '/home/kris/linuxcnc/configs/my_mill'
Machine configuration file is 'my_mill.ini'
INIFILE=/home/kris/linuxcnc/configs/my_mill/my_mill.ini
VERSION=1.1
PARAMETER_FILE=probe_basic.var
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
KINEMATICS=trivkins coordinates=XYZ
Starting LinuxCNC...
Starting LinuxCNC IO program: iov2
twopass:invoked with <> options
twopass:found ./main.hal
twopass:CANNOT FIND FILE FOR:io.hal
iov2: exiting
Debug file information:
Note: Using POSIX realtime
2139
Stopping realtime threads
Unloading hal components
Info report created by linuxcnc_info:
The file: /tmp/linuxcnc_info.txt
can be posted to a forum or a web site like:
pastebin.com
in order to provide information about the linuxcnc
system and configuration.
Date: Fri Nov 21 08:56:05 AM CST 2025
UTC Date: Fri Nov 21 02:56:05 PM UTC 2025
this program: /usr/bin/linuxcnc_info
uptime: 08:56:05 up 3 min, 1 user, load average: 1.44, 0.72, 0.30
lsb_release -sa: Debian Debian GNU/Linux 13 (trixie) 13 trixie
linuxcnc: /usr/bin/linuxcnc
pwd: /home/kris/linuxcnc/configs/my_mill
USER: kris
LOGNAME: kris
HOME: /home/kris
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
DESKTOP: lightdm-xsession
display size: 1920x1080 pixels (509x286 millimeters)
PATH: /usr/bin:/home/kris/linuxcnc/configs/my_mill/bin:/usr/bin:/usr/local/bin:/usr/bin:/bin:/usr/local/games:/usr/games
uname items:
nodename -n: debian
kernel-name -s: Linux
kernel-vers -v: #1 SMP PREEMPT_RT Debian 6.12.48-1 (2025-09-20)
machine -m: x86_64
processor -p: unknown
platform -i: unknown
oper system -o: GNU/Linux
/proc items:
cmdline: BOOT_IMAGE=/boot/vmlinuz-6.12.48+deb13-rt-amd64 root=UUID=5efc6035-1184-4e51-acb6-e99aeeac4490 ro quiet isolcpus=3
model name: Intel(R) N100
cores: 4
cpu MHz: 1744.606
parport:
serial:
Versions:
gcc: gcc (Debian 14.2.0-19) 14.2.0
python: Python 3.13.5
git: not_in_PATH
git commit: NA
tcl: 8.6
/usr/bin/linuxcnc_info: line 159: wish: command not found
tk:
glade: not_in_PATH
linuxcnc_var all:
LINUXCNCVERSION: 2.9.4
LINUXCNC_AUX_GLADEVCP: /usr/share/linuxcnc/aux_gladevcp
LINUXCNC_AUX_EXAMPLES: /usr/share/linuxcnc/aux_examples
REALTIME: /usr/lib/linuxcnc/realtime
RTS: uspace
HALLIB_DIR: /usr/share/linuxcnc/hallib
PYTHON: /usr/bin/python3
dpkg -l '*linuxcnc*':
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
un linuxcnc <none> <none> (no description available)
un linuxcnc-dev <none> <none> (no description available)
un linuxcnc-doc <none> <none> (no description available)
ii linuxcnc-doc-en 1:2.9.4-2 all motion controller for CNC machines and robots (English documentation)
un linuxcnc-doc-es <none> <none> (no description available)
un linuxcnc-doc-fr <none> <none> (no description available)
un linuxcnc-sim <none> <none> (no description available)
un linuxcnc-sim-dev <none> <none> (no description available)
ii linuxcnc-uspace 1:2.9.4-2 amd64 motion controller for CNC machines and robots
ii linuxcnc-uspace-dev 1:2.9.4-2 amd64 PC based motion controller for real-time Linux
RUN_IN_PLACE=no
LINUXCNC_DIR=
INIVAR=inivar
HALCMD=halcmd
LINUXCNC - 2.9.4
VERSION=1.1
TPMOD=
HOMEMOD=
TASK=milltask
HALUI=halui
DISPLAY=probe_basic
COORDINATES=X Y Z
iov2: exiting
2139
pastebin.com
USER: kris
LOGNAME: kris
HOME: /home/kris
EDITOR:
VISUAL:
LANGUAGE:
TERM: dumb
COLORTERM:
DISPLAY: :0.0
uname items:
nodename -n: debian
machine -m: x86_64
/proc items:
cores: 4
cpu MHz: 1744.606
parport:
serial:
Versions:
git: not_in_PATH
git commit: NA
tcl: 8.6
tk:
glade: not_in_PATH
linuxcnc_var all:
RTS: uspace
21 Nov 2025 15:23 #338901
seems that you are telling it to load 'io.hal' somewhere but don't have that file in your config.
