Probe basic launch issue
21 Nov 2025 15:26 #338902 by tommylight
Replied by tommylight on topic Probe basic launch issue
The ini file is pointing to an io.hal file that does not exist in that folder.
You can try omitting that entry in the ini file, but might be needed for the config to work, so better try to find the file if you are sure it is needed.
21 Nov 2025 15:33 #338904 by Tinker
Replied by Tinker on topic Probe basic launch issue
I'm sure I messed something up again.. here's a copy of my HAL& INI files
HAL
# This file was created with the Mesa Configuration Tool on Nov 21 2025 06:35:29
# If you make changes to this file DO NOT run the configuration tool again!
# This file will be replaced with a new file if you do!
# kinematics
loadrt [KINS](KINEMATICS)
# motion controller
loadrt [EMCMOT]EMCMOT servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[KINS]JOINTS num_dio=6 num_aio=3
# hostmot2 driver
loadrt hostmot2
loadrt [HM2](DRIVER) board_ip=[HM2](ADDRESS) config="sserial_port_0=00000000"
setp hm2_[MESA](BOARD).0.watchdog.timeout_ns 10000000
loadrt pid names=pid.x,pid.y,pid.z
# THREADS
addf hm2_[MESA](BOARD).0.read servo-thread
addf pid.x.do-pid-calcs servo-thread
addf pid.y.do-pid-calcs servo-thread
addf pid.z.do-pid-calcs servo-thread
addf hm2_[MESA](BOARD).0.write servo-thread
# amp enable
net motion-enable <= motion.motion-enabled
# Global PWM setup
setp hm2_[MESA](BOARD).0.pwmgen.pwm_frequency 75000
# Board: 7i97t
# Axis: X Joint: 0 Output: 0
# PID Setup
setp pid.x.Pgain [JOINT_0](P)
setp pid.x.Igain [JOINT_0](I)
setp pid.x.Dgain [JOINT_0](D)
setp pid.x.bias [JOINT_0](BIAS)
setp pid.x.FF0 [JOINT_0](FF0)
setp pid.x.FF1 [JOINT_0](FF1)
setp pid.x.FF2 [JOINT_0](FF2)
setp pid.x.deadband [JOINT_0](DEADBAND)
setp pid.x.maxoutput [JOINT_0](MAX_OUTPUT)
setp pid.x.error-previous-target True
# joint-0 enable chain
net joint-0-index-enable <=> pid.x.index-enable
net joint-0-index-enable <=> joint.0.index-enable
net joint-0-index-enable <=> hm2_[MESA](BOARD).0.encoder.00.index-enable
net joint-0-enable <= joint.0.amp-enable-out
net joint-0-enable => pid.x.enable
net joint-0-enable => hm2_[MESA](BOARD).0.pwmgen.00.enable
# PWM Generator setup
setp hm2_[MESA](BOARD).0.pwmgen.00.dither true
setp hm2_[MESA](BOARD).0.pwmgen.00.output-type 1 #PWM pin0
setp hm2_[MESA](BOARD).0.pwmgen.00.offset-mode 1 # offset mode so 50% = 0
setp hm2_[MESA](BOARD).0.pwmgen.00.scale [JOINT_0]SCALE
setp hm2_[MESA](BOARD).0.encoder.00.counter-mode 0
setp hm2_[MESA](BOARD).0.encoder.00.filter 1
setp hm2_[MESA](BOARD).0.encoder.00.index-invert 0
setp hm2_[MESA](BOARD).0.encoder.00.index-mask 0
setp hm2_[MESA](BOARD).0.encoder.00.index-mask-invert 0
setp hm2_[MESA](BOARD).0.encoder.00.scale [JOINT_0]ENCODER_SCALE
# position command and feedback
net joint-0-pos-cmd <= joint.0.motor-pos-cmd
net joint-0-pos-cmd => pid.x.command
net joint-0-pos-fb <= hm2_[MESA](BOARD).0.encoder.00.position
net joint-0-pos-fb => joint.0.motor-pos-fb
net joint-0-pos-fb => pid.x.feedback
# PID Output
net joint.0.output <= pid.x.output
net joint.0.output => hm2_[MESA](BOARD).0.pwmgen.00.value
# Encoder Setup
setp hm2_[MESA](BOARD).0.encoder.00.scale [JOINT_0](ENCODER_SCALE)
INI
# This file was updated with the Mesa Configuration Tool on Nov 21 2025 06:35:29
# Changes to most things are ok and will be read by the Configuration Tool
[MESA]
VERSION = 2.1.8
BOARD = 7i97
BOARD_NAME = 7i97t
FIRMWARE =
CARD_0 = None
CARD_1 = None
[EMC]
VERSION = 1.1
MACHINE = my mill
DEBUG = 0x00000000
[HM2]
DRIVER = hm2_eth
ADDRESS = 10.10.10.10
[DISPLAY]
DISPLAY = probe_basic
OPEN_FILE = ~/linuxcnc/nc_files/pb_examples/blank.ngc
CONFIRM_EXIT = False
LOG_FILE = sim.log
LOG_LEVEL = DEBUG
PREFERENCE_FILE = sim.pref
CONFIG_FILE = custom_config.yml
POSITION = 0x0
PROGRAM_PREFIX = /home/kris/linuxcnc/nc_files
POSITION_OFFSET = RELATIVE
POSITION_FEEDBACK = ACTUAL
MAX_FEED_OVERRIDE = 2.000000
MAX_SPINDLE_OVERRIDE = 2.000000
MIN_SPINDLE_OVERRIDE = 0.500000
DEFAULT_SPINDLE_SPEED = 300
MIN_LINEAR_VELOCITY = 0.016670
DEFAULT_LINEAR_VELOCITY = 10.00000
MAX_LINEAR_VELOCITY = 10.000000
DEFAULT_ANGULAR_VELOCITY = 36.000000
MAX_ANGULAR_VELOCITY = 360.000000
MIN_ANGULAR_VELOCITY = 1.666667
PROGRAM_PREFIX = ~/linuxcnc/nc_files
INCREMENTS = JOG .01in .001in .0001in
GEOMETRY = xyzac
USER_TABS_PATH = user_tabs/
USER_BUTTONS_PATH = user_buttons/
USER_DROS_PATH = user_dro_display/
DRO_DISPLAY = XYZ
OFFSET_COLUMNS = XYZR
TOOL_TABLE_COLUMNS = TZDR
KEYBOARD_JOG = true
KEYBOARD_JOG_SAFETY_OFF = true
ATC_TAB_DISPLAY = 0
USER_ATC_BUTTONS_PATH = user_atc_buttons/
CYCLE_TIME = 0.1
INTRO_TIME = 1
OPEN_FILE = ""
[KINS]
KINEMATICS = trivkins coordinates=XYZ
JOINTS = 3
[EMCIO]
EMCIO = iov2
CYCLE_TIME = 0.100
TOOL_TABLE = tool.tbl
[RS274NGC]
RS274NGC_STARTUP_CODE = F10 S300 G20 G17 G40 G49 G54 G64 P.001 G80 G90 G91.1 G92.1 G94 G97 G98
PARAMETER_FILE = probe_basic.var
OWORD_NARGS = 1
NO_DOWNCASE_OWORD = 1
SUBROUTINE_PATH = subroutines
[EMCMOT]
EMCMOT = motmod
COMM_TIMEOUT = 1.0
SERVO_PERIOD = 2000000
[TASK]
TASK = milltask
CYCLE_TIME = 0.010
[TRAJ]
AXES = 3
COORDINATES = X Y Z
LINEAR_UNITS = inch
ANGULAR_UNITS = degree
MAX_LINEAR_VELOCITY = 3.4
NO_FORCE_HOMING = 1
[HAL]
HALUI = halui
POSTGUI_HALFILE = probe_basic_postgui.hal
TWOPASS = on
HALFILE = main.hal
HALFILE = io.hal
[AXIS_X]
MIN_LIMIT = -14
MAX_LIMIT = 14
MAX_VELOCITY = 10
MAX_ACCELERATION = 10
[JOINT_0]
CARD = 0
TAB = 0
AXIS = X
MIN_LIMIT = -14
MAX_LIMIT = 14
MAX_VELOCITY = 10
TYPE = LINEAR
SCALE = 4
ANALOG_SCALE_MAX = 10
ANALOG_MIN_LIMIT = -10
ANALOG_MAX_LIMIT = 10
ENCODER_SCALE = -40000
FERROR = 25
MIN_FERROR = 25
DEADBAND = 0
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
MAX_OUTPUT = 100
MAX_ERROR = 25
HOME = 0
HOME_OFFSET = -14
HOME_SEARCH_VEL = -1
HOME_LATCH_VEL = 1
HOME_FINAL_VEL = 0
HOME_USE_INDEX = True
HOME_IGNORE_LIMITS = True
HOME_IS_SHARED = True
[AXIS_Y]
MIN_LIMIT = -9
MAX_LIMIT = 9
MAX_VELOCITY = 10
[JOINT_1]
CARD = 0
TAB = 1
AXIS = Y
MIN_LIMIT = -9
MAX_LIMIT = 9
MAX_VELOCITY = 10
TYPE = LINEAR
SCALE = 4
FERROR = 25
MIN_FERROR = 25
DEADBAND = 0
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
MAX_OUTPUT = 100
MAX_ERROR = 25
HOME = 0
HOME_OFFSET = -9
HOME_LATCH_VEL = 1
HOME_FINAL_VEL = 0
[AXIS_Z]
MIN_LIMIT = -17
MAX_LIMIT = 0
MAX_VELOCITY = 5
MAX_ACCELERATION = 5
[JOINT_2]
CARD = 0
TAB = 2
AXIS = Z
MIN_LIMIT = -17
MAX_LIMIT = 0
MAX_VELOCITY = 5
TYPE = LINEAR
SCALE = 4
ENCODER_SCALE = 40000
FERROR = 25
MIN_FERROR = 25
DEADBAND = 0
P = 10
I = 0
D = 0
FF0 = 0
FF1 = 1
FF2 = 0
BIAS = 0
MAX_OUTPUT = 100
MAX_ERROR = 25
HOME = -1
HOME_OFFSET = 0
HOME_SEARCH_VEL = 1
HOME_LATCH_VEL = 1
HOME_FINAL_VEL = 0
[INPUTS]
# DO NOT change the inputs they are used by the configuration tool
INPUT_0_8 = Joint 0 Plus Minus Home
INPUT_INVERT_0_8 = True
INPUT_SLOW_0_8 = False
INPUT_0_9 = Joint 1 Minus Home
INPUT_INVERT_0_9 = True
INPUT_SLOW_0_9 = False
INPUT_0_10 = Joint 1 Plus
INPUT_INVERT_0_10 = True
INPUT_SLOW_0_10 = False
INPUT_0_11 = Joint 2 Plus Home
INPUT_INVERT_0_11 = True
INPUT_SLOW_0_11 = False
INPUT_0_12 = Joint 2 Minus
INPUT_INVERT_0_12 = True
INPUT_SLOW_0_12 = False
INPUT_0_14 = Lube Level
INPUT_INVERT_0_14 = False
INPUT_SLOW_0_14 = False
[OUTPUTS]
# DO NOT change the outputs they are used by the configuration tool
OUTPUT_0_0 = Spindle CW
OUTPUT_INVERT_0_0 = False
OUTPUT_0_1 = Spindle CCW
OUTPUT_INVERT_0_1 = False
OUTPUT_0_2 = Coolant Flood
OUTPUT_INVERT_0_2 = False
OUTPUT_0_3 = Lube Pump
OUTPUT_INVERT_0_3 = False
[OPTIONS]
# DO NOT change the options they are used by the configuration tool
LOAD_CONFIG = True
INTRO_GRAPHIC_TIME = 0
MANUAL_TOOL_CHANGE = True
CUSTOM_HAL = False
POST_GUI_HAL = False
SHUTDOWN_HAL = False
HALUI = False
PYVCP = False
GLADEVCP = False
LADDER = False
BACKUP = True
21 Nov 2025 15:44 #338907 by Tinker
I omitted that file and the GUI launched but with a new error.. LOL This thing is driving me crazy.
File "/usr/bin/probe_basic", line 8, in <module>
sys.exit(main())
File "/usr/lib/python3/dist-packages/probe_basic/__init__.py", line 20, in main
qtpyvcp.run_vcp(opts, VCP_CONFIG_FILE)
File "/usr/lib/python3/dist-packages/qtpyvcp/__init__.py", line 26, in run_vcp
run(*args, **kwargs)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/__init__.py", line 129, in run
launch_application(opts, config)
File "/usr/lib/python3/dist-packages/qtpyvcp/app/launcher.py", line 93, in launch_application
raise IOError('The specified POSTGUI_HALFILE does not exist: %s' %
postgui_halfile)
OSError: The specified POSTGUI_HALFILE does not exist: /home/kris/linuxcnc/configs/my_mill/probe_basic_postgui.hal
21 Nov 2025 16:10 #338909 by Tinker
I had to move some files around, but i think i have it working. Thank you so much for all of yalls help! Yall are the best!!!!
Time to create page: 0.209 seconds
